Cam Followers!?
Old Jul 28, 2005 | 11:26 PM
RonRon's Avatar
RonRon
Default Cam Followers!?
Ok my cylinderhead is currently taken off my engine because i have to renew the head gasket.. Now i am sitting with my cylinderhead and are about to remove my camshaft..
I have removed the camfollowers and here is my question:
This is my normal camfollower..
But is this supposed to happen???
The camfollower is in three parts.. but some of them can not be separated like that... Can someone please explain to me if this is normal or if some of my camfollowers is damaged?? i dont know much about this part of engine
Anyway.. if i want to renew my camfollowers... will i have to buy a new camshaft too?? or can i renew only the camfollowers??
Old Jul 28, 2005 | 11:35 PM
GrimmeRS2K's Avatar
GrimmeRS2K
never seen any of mine do that mate, that ring is properly a retainer or something when they are made
when fitting a new camshaft, always replace the followers, along with new oil
but the other way round isnt as bad, but a worn cam can soon knock out the new followers
if u can afford it, buy a camkit, you get everything in the kit, and do everything all together, stems,springs, followers etc, rs turbos/cvh's cams tend to wear after 60k and are normally replaceded then
Old Jul 28, 2005 | 11:59 PM
RonRon's Avatar
RonRon
yeah... but the problem is that i cant afford a camkit right now.. but i could probably just use these followers again and then replace the whole mess when i can afford it..
i was just thinkin of renewing the followers because they are ticking and i hate that sound
Old Jul 29, 2005 | 12:24 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i wouldnt even think about putting those followers back in mate, buy some new ones!
Old Jul 29, 2005 | 12:47 PM
rs_daz's Avatar
rs_daz
If u put that back in it will just tap like a bugger .. id fit a new set
Old Jul 29, 2005 | 12:49 PM
davidnormanuk's Avatar
davidnormanuk
You can get a brand new standard cam kit made by AE for £104.00
I've got some spare followers you can have for next to nothing if you need them. They would probably do you while you save up to get a kit.
Dave
Old Jul 29, 2005 | 01:35 PM
RonRon's Avatar
RonRon
Damn!!
well... i must try to find some money for a complete set then..
but can i break something if i put in some new followers without changing the camshaft??
Old Jul 29, 2005 | 02:45 PM
mart.rs's Avatar
mart.rs
Default standard cam
Dave
sorry to interupt but dont suppose you have the number for them do you as i need a new standard one!
Old Jul 29, 2005 | 03:31 PM
davidnormanuk
The place where I got the kit from is called Godfrey Autoparts in Leeds. Their number is 0113 2469009. AE is the make of the cam who are based in Bradford they are well know throughout the country. They also make good quality pistons etc.
Dave
Mc5506
Oct 5, 2015 09:57 PM
