Wot stage is my cossie??
Old Jul 28, 2005 | 06:35 PM
nice_head's Avatar
nice_head
Default Wot stage is my cossie??
Just wondering at wot stage my cossie is running at? She's got a set of green injectors, chip, 3 bar map sensor, -31 acuator and a standard T3 wiv 360 kit..
Alot of peeps say its stage 2 or 3?
Old Jul 28, 2005 | 09:09 PM
Kam B's Avatar
Kam B
stage 3 mate
Old Jul 29, 2005 | 09:20 AM
john_p_b's Avatar
john_p_b
i'd have said stage 2, i've always been told stage 3 is pretty much as above but with the addition of a T3/4 turbo?
Old Jul 29, 2005 | 12:31 PM
nice_head's Avatar
nice_head
So wots stage 1 and 2 then?
Old Jul 29, 2005 | 12:50 PM
john_p_b's Avatar
john_p_b
IMO
stage 1 = 270 chip, cone filter, exhaust.
stage 2 = 330 chip, 3 bar map senson, -31 actuator, filter, exhaust, rs500 type intercooler.
stage 3 = as stage 2 but with the addition of a T3/4 turbo
basicly the above stages are off the shelf parts that can (if you're confident) install as a diy job.
Old Aug 1, 2005 | 02:57 PM
JamesH's Avatar
JamesH
Well, IMO:
Stage1 = 270/280 Chip, Air Filter, Exhaust (15-17 psi)
Stage2 = 330 Chip, Green Injectors, Air Filter, Exhaust, 3 bar map sensor, -31 actuator, 4x4 intercooler (if it's a 2wd), and standard T3 (18-22psi)
Stage3= 330 Chip, Green Injectors, Air Filter, Exhaust, 3 bar map sensor, -31 actuator, 4x4 intercooler (if it's a 2wd), RS500 Style Intercooler, and a T35/T35 running more boost than stage 2 (22-26psi BUT MUST BE SETUP AT THIS POINT AS THAT MUCH BOOST IS PUSHING GREENS TO THEIR LIMIT)
Old Aug 1, 2005 | 03:01 PM
Graceland's Avatar
Graceland
Team HOTHOT!
stage 3 is what you do not have.
you have a stage 2 conversion
Stage 3 is the adition of a T34
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
