Boiling Header tank! Help needed
Old Jul 27, 2005 | 10:32 PM
BlackRs's Avatar
BlackRs
Default Boiling Header tank! Help needed
I have recently bought a Escort RST and when returned from taking it for a test drive i heard the water bubbling and boiling in the header tank. When i asked the previous owner he told me that is has only done this since the new stainless steel tank has been put on there. Is this true or is there a problem? I have checked for the common head gasket failure signs but no oil in water or water in oil.
any helped gratefully apreciated
Old Jul 28, 2005 | 01:03 AM
antony215's Avatar
antony215
Escort Rs Turbo
make sure that the water is at the right level if you over fill it that will make it boilover. is the fan kickin in? putin a stainless header tank on should'nt make it do that mine's been ok.
Old Jul 28, 2005 | 09:43 AM
swerv's Avatar
swerv
put a pic up of the header tank and cap , there are some very dodgy header tanks doing the rounds which WILL knacker your engine
make sure you have a valve inside the tank cap as well
steerfromdarear
28
Jan 29, 2016 06:14 PM
ekjim
Aug 17, 2015 08:57 PM
155lee
Aug 14, 2015 11:21 AM
col93saphcos
Aug 7, 2015 03:21 PM
