Blow off valve noise???
My mate has a scooby and wants that high pitched sqeaking noise they can have!!!!
Am i right in saying that is a blow off valve rather than a dump valve?!?!?
Thanks
Nick b
Thanks
Nick b
I think you mean chatter, in which case you want neither a dump valve or blow off valve as they are also called.
As to whether it will be high pitched like rally cars, that depends on the turbo, boost, etc...
Hope this helps.
Hope this helps.
Yes you could fit 1 to a cossy i would imagin they are the same as all other dv's blow off valve or what ever you want to call em only the SQV is slightly more high pitched and because its made by HKS more expencive
ive got a GReddy TypeS on my cossie, sounds the nuts!!!!
i did have a HKSsspv on, but didnt really like it.
and if you want to listern to some BOV noises and see a few vids
http://www.blowoffvalves.com/
SMILER258
Sep 28, 2015 09:04 AM
