2wdsapphire chassis mods, ARB`s bottom arms from ESCOS??
Old Jul 27, 2005 | 05:20 PM
Mr C's Avatar
Mr C
Default 2wdsapphire chassis mods, ARB`s bottom arms from ESCOS??
I have a `90 2wd sapphire cosworth in need of handling mods. I have AVO coilovers, ESCORT COS 26mm Rear ARB on the way and adjustable bottom arms for the front. What else can I do to help the front end turn in and grip and get the whole car to handle better, more predictably etc? Solid top mounts, front and rear strut braces, roll cage, seam welding? what will make the most difference for the money
Old Jul 29, 2005 | 10:07 PM
BigG_NE's Avatar
BigG_NE
What about Compression Strut to replace current ARB and then Blade type leading ARB?
This is s'posed to be good for Tarmac Racing and Rallying.
Good Luck
G
Old Jul 30, 2005 | 04:15 PM
STUCOS's Avatar
STUCOS
Roller top mounts,can supply at £140 + post,compresion struts would also help,what spring rates you using
cheeRS stu
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
