What sort of charge temps are you running?
Old Jul 25, 2005 | 08:17 PM
kossie's Avatar
kossie
Default What sort of charge temps are you running?
I pulled my finger out, and the Ka isnt far off.
I was wondering what sort of charge temps you lot run? i cant run any sexy pace/grs front mount for obvious reason. But the cooler i do have fills every inch avaliable on the front of the Ka Its something like 600mm x 175mm x 65mm
Want to know how effectve its gonna be, or restrictive at all.
Old Jul 25, 2005 | 08:39 PM
Oranoco's Avatar
Oranoco
My Pace front mount rarely see's above 33degrees on the move. If it does stray over 40 then I can use the water injection but so far it hasn't been required
Old Jul 26, 2005 | 05:18 AM
gus's Avatar
gus
mine reads about the 40 mark, would like them lower thou so maybe something else coming soon
does anyone know where i could get a temp gauge to read the inlet temps so i know how well me cooler is doing
Old Jul 26, 2005 | 09:00 AM
addiction's Avatar
addiction
mine never goes above 34 degrees no matter how hard i drive it or how hot the day is
Old Aug 14, 2005 | 04:33 PM
lith's Avatar
lith
hello mate my charge cooler runs about 33 degrees somes times up to 38 if i drive it hard hope that helps
Old Aug 18, 2005 | 09:27 AM
James Raby's Avatar
James Raby
Mike Does the ACT gauge with 2 settings, so can have 2 readings with flick of switch, I have
Old Aug 18, 2005 | 09:31 AM
moonstonematt's Avatar
moonstonematt
James Raby,
but the act gauge doent go above 70 degrees so you wont be able to put it on the hot side of the intercooler cos it goes over 130 degrees at full chat
Old Aug 18, 2005 | 09:35 AM
James Raby's Avatar
James Raby
Why do you want it on the hot side for?
Want it as it comes out of the cold pipe (as that's what the true reading of the cooler is) AND on the inlet manifold IMO
Harryh24
Aug 26, 2015 07:50 PM
Kop2381
Aug 23, 2015 01:17 AM
kosienutter
31
Aug 22, 2015 09:55 AM
COSWORLD
Aug 14, 2015 07:40 AM
