What parts are the same for both s1 and s2?
Old Jul 24, 2005 | 04:35 PM
series1 ant's Avatar
series1 ant
Default What parts are the same for both s1 and s2?
just interested to know what parts are exactly the same including engine and exterior parts. sorry if this has been asked before but ive owned a s1 for 3 years now and i have never really thought about it.
thanks
anthony
Old Jul 25, 2005 | 01:04 PM
Hatch's Avatar
Hatch
there isnt a lot i dont think thats the same off the top of my head . basic shells the same apart from the obvious rear panel , wings , front panel , bonnet , door internal panel etc
you could make a S2 into a S1 or the other way round fairly easy
Old Jul 25, 2005 | 01:15 PM
AJC's Avatar
AJC
engine parts different, inlet manifold different, i think metering heads are different
the turbo is water cooled on s2 where as s1 is oil cooled
Old Jul 25, 2005 | 02:15 PM
Tombra's Avatar
Tombra
Also flywheel/clutch is different, S1 uses 200mm clutch, S2 uses 220mm.
Iam running S1 engine in a S2 shell, no problems
Old Jul 25, 2005 | 04:02 PM
mart.rs's Avatar
mart.rs
nice motor mate but lose the spoiler for somthing more subtle ,p.s series1ant
the water pumps are different too
Old Jul 25, 2005 | 04:04 PM
Oranoco's Avatar
Oranoco
STandard repeaters are the same. (where fitted)
Old Jul 25, 2005 | 04:18 PM
bzd32's Avatar
bzd32
the gearbox is different due to the mount bracket, modified engine management, slighly bigger water pump, different drive shafts, bigger front brake and as ajc and tombra said
plus some other thing
thing can be inter changed (there is always a way )
Old Jul 25, 2005 | 08:56 PM
JesseT's Avatar
JesseT
Actually they are not.
Old Jul 25, 2005 | 09:37 PM
AJC's Avatar
AJC
forgot bout flywheel
my car has an s2 flywheel for alcon paddle clutch
Old Jul 26, 2005 | 08:00 AM
JesseT's Avatar
JesseT
It's surprising, but perhaps 5% of parts are identical between S1 and S2, but 95% of parts can be exchanged if really needed.
gambo08
Feb 4, 2016 10:49 PM
Oct 1, 2015 02:00 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
