help cos electrical problems
Old Jul 23, 2005 | 08:41 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
Default help cos electrical problems
a brief spec of whats been done,mountune engine, 4x4 saff engine and abs loom . escort p8 ecu. the problem seems to be a lack of earth conections from the ecu.ie the fuel pump relay has no earth,the i s c v has no earth.i wired my own relay for the fuel pump.and the engine will start and run if i keep my foot on the throttle. the earth from the injector loom is ok. so has anybody got a idea of whats wrong? crank sensor and phase sensor gaps are ok.all the wires at the multi plugs have been cut and soldered.
Old Jul 24, 2005 | 01:15 AM
jon@work's Avatar
jon@work
The fuel pump relay and the ISCV both earth through the ECU and as such don't have their own earths.
Old Jul 27, 2005 | 08:14 PM
Dave Henshall's Avatar
Dave Henshall
there should be 2 earthe form the ecu pinms that come through the bulkhead and earth on the back of th inlet manifold, from pins, 1 and 19 IIRC..
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
S3an
Sep 26, 2015 11:39 PM
`spotty
Sep 25, 2015 11:41 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
