Flamer Kit
Old Jul 23, 2005 | 08:35 PM
Turbo-T34's Avatar
Turbo-T34
Default Flamer Kit
Okay, bought a flamer kit for my RST, drilled hole in exahust and mounted spark plug.
Ran wires to switch then onto the coil, tested it, its sparking okay.
Turn on car, revved it a little, no flames. Took it out for a spin, still no flames.
Even adjusted the air/fuel ratio screw to run a bit more rich, still no flames.
So how come its not flaming?!?!?!?!
Do i need to adjust the spark plug gap, cos it looks like a good few thousand, was standard out the spark plug box.
Any ideas?
Old Jul 23, 2005 | 10:06 PM
Patto's Avatar
Patto
were abouts you put the plug in the exhaust?
have you tried driving it hard then lifting off?
CheeRS
Craig
NYRSOC
Old Jul 23, 2005 | 10:11 PM
swanny's Avatar
swanny
FYI the plug needs to be fitted in the back-box, after the baffels / last box. I found the best method to get my old s2 to flame was to drive her about for a bit so she warmed up, then take her up to say 5k in 2nd / 3rd and then totally let go of the accelorator pedal. when u do this, it'll drop down to about 3k and u should see a small flame from behind (easiest time to practise is at night as u can see the flame in mirror)... Once u can see the little flame, give the accel pedal a little tap / feather and u should be able to shoot big flames / fire-balls out of the back
It does take a bit of practise, but well worth it once u get the hang of it. A word of warning, alot of reving ur car up then letting it idle back down doesnt do the gearbox a whole lot of good... fudged mine over time doing the above
Let me know how u get on
Old Jul 24, 2005 | 12:44 AM
NUTS RuS's Avatar
NUTS RuS
Bin it
Old Jul 24, 2005 | 06:09 AM
swanny's Avatar
swanny
No! They a good crack, especially when u get a fag in a nova sat up ur arse around town... melt their stupid oversized bumpers!!
Old Jul 24, 2005 | 08:29 AM
NUTS RuS's Avatar
NUTS RuS
No bumper is fine - the lighter it is the quicker it will go
Old Jul 24, 2005 | 10:37 AM
Turbo-T34's Avatar
Turbo-T34
its fitted after the backbox/baffles, but before the exhaust tip.
I have read your advice and i shall try it again!
Thanks!
Old Jul 24, 2005 | 02:07 PM
james_birch's Avatar
james_birch
hammer it down a road...then lift off sharply then tap the throttle...
or if ya want them to swirl.....hammer is then lift off really slowly! u wont see it but it will swirl in ya zorst then pop out a little!
Old Jul 24, 2005 | 08:26 PM
andyt's Avatar
andyt
yeah im with you nuts bin it
Old Jul 25, 2005 | 11:37 AM
NUTS RuS's Avatar
NUTS RuS
andyt,
Old Jul 25, 2005 | 11:57 AM
Oranoco's Avatar
Oranoco
Flamer kits are juvenile and pointless
They are however quite a lot of fun. I know people take the piss but I love mine
Rick's Avatar
Rick
Lol - im just about to connect mine - it's good for melting knobs in Porka's bumpers....
How did u fit the plug?
Old Jul 25, 2005 | 12:55 PM
adamS2RST's Avatar
adamS2RST
IS the car chipped?
Old Jul 25, 2005 | 04:32 PM
Turbo-T34's Avatar
Turbo-T34
i dont think the car is chipped, i need to take it to a tuner soon when i have some money to have it looked over.
The kit that i bought (from Ford Fair last year) had a threaded metal washer which you weld to the exhaust, and the spark plug just screws into that!
Old Jul 25, 2005 | 04:45 PM
Piinko-RS's Avatar
Piinko-RS
i fitted 1 on my mates car as close as i could to the back box but still on the end pipe, i 'think' when its to close to the end the exhaust gases get weaker as they mixing with air and they are harder to ignite,
Old Jul 25, 2005 | 06:11 PM
Oranoco's Avatar
Oranoco
Have you looked to see if the plug is sparking?
Take it for a drive with the kit on and get everything nice and warm. Mine does nothing until it's up to temp and then it flames like a dragon
Old Jul 25, 2005 | 07:26 PM
CliffRS4's Avatar
CliffRS4
Originally Posted by NUTS RuS
Bin it
Too right as they are gay
Old Jul 26, 2005 | 08:01 AM
adamS2RST's Avatar
adamS2RST
I must admit I have one on my car, but only because it was on my old S2 and I used the system from that on my new one as I broke the old car. I don't use it, but as my current S2 is not chipped and standard it wont flame anyway!
Old Aug 4, 2005 | 08:25 PM
L33 BYT's Avatar
L33 BYT
Adam - Sell that flamer!!!
TO me!
Old Aug 4, 2005 | 10:32 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
mate bin the flamer kit and buy a turbo big as your head, then it'l flame all by itself
Old Aug 5, 2005 | 12:07 AM
rs_daz's Avatar
rs_daz
I had my car tuned and it dont flame at all now lol even with the flamer on
Old Aug 5, 2005 | 07:14 AM
Turbo-T34's Avatar
Turbo-T34
LOL!
Truck turbo then?
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
