FAO: Any Electronics guru's need help
Old Jul 21, 2005 | 08:28 AM
RSeb's Avatar
RSeb
Default FAO: Any Electronics guru's need help
Am currently starting a project on an automatic sliding door system (for my btec), you know like you find at the shop's, can anyone out there throw any info my way or suggest companies/websites where i can get some technical data ie wiring diagrams componant listngs and health and safety issues.
My initially idea is to use a motion detector (like on a security light) either side of the door to open
or an infrared beam to detect motion
then a pressure sensor or bimetalic strip on the door edge to avoid the door closing on someone.
The door must remain open for 10 seconds and open/close between 4-6 seconds
Any help will be much appreciated cos i can't find squat on the net at the mo
Cheers Seb
Old Jul 21, 2005 | 10:13 AM
RSeb's Avatar
RSeb
come on peeps
Old Jul 21, 2005 | 12:34 PM
RSeb's Avatar
RSeb
boing
Old Jul 21, 2005 | 12:49 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Theres a few people who may be able to help on here, hopefully they'll see this topic
In the mean time, have a look at www.electro-tech-online.com, a good electronics forum, may be people there who can assist
Old Jul 21, 2005 | 03:08 PM
RSeb's Avatar
RSeb
cheers phil, i'm sure there must be some clever blokes on here
Old Jul 21, 2005 | 03:47 PM
focusv8's Avatar
focusv8
I am employed on building services under contract to a major supermarket.
I can answer questions on auto doors, but as its for your Btec I will not supply large quantities of text that you might cut and paste unaltered!!!!!!!!!
Auto doors use detectors both sides.
A pressure strip on the edge will mean hitting the customer!!!!!! not good, think again.
Children and coffin dodgers??
What happens in the event of a fire?
Have you looked here:
http://www.irdoromatic.co.uk/index.php
Old Jul 21, 2005 | 04:10 PM
RSeb's Avatar
RSeb
will do now, we've worked out about the sensors either side, am thinking of pressure sensor in the floor for someone stuck in the doorway, and fire regs say door must fail safe to open OR be able to push out, will proly go with the later, more building less programming that way!
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
cossie brad
Sep 29, 2015 02:38 PM
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
