S1/S2 Rear suspension differences?
Old Jul 20, 2005 | 10:19 PM
Rick's Avatar
Rick
Default S1/S2 Rear suspension differences?
Are there any? Bushes etc?
Old Jul 20, 2005 | 10:32 PM
DazC's Avatar
DazC
12mm anti roll bar on an S1 and a 16mm anti roll bar on the S2.
That is the only difference if I recall correctly....
Old Jul 20, 2005 | 11:07 PM
Tim's Avatar
Tim
Adj rear link arms on some S1's
Old Jul 21, 2005 | 07:44 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
would it be wise to change to an S2 anti roll bar?
Old Jul 21, 2005 | 07:50 AM
Why ?
RS1600i has the best standard setup
Old Jul 21, 2005 | 08:26 AM
Red16's Avatar
Red16
woohoo
Old Jul 21, 2005 | 09:51 AM
vroooom ptssssh
It Wasnt Me!
dingy, Correct, but an S2 seems to have a bigger roll bar than an S1 hence the question "would it be wise to change to an S2 roll bar"
ofcourse a 16I setup would be the best, but you dont see many parts for em kicking around, or at the price of 2 roll bar which will be better than an S1 i would think
Old Jul 21, 2005 | 09:58 AM
Rick's Avatar
Rick
Vroom - No. Antiroll bars should be as small as possible to stop excessive roll.
Tim - do you mean the tie bars? and how come only some S1's?
Reason i ask, is that im sure i saw the rear wishbone bushes advertised as a diff part no to S2.
Old Jul 21, 2005 | 10:37 AM
John Laverick's Avatar
John Laverick
Larger rear anit-roll bar doesn't automatically mean better handling!!
It can sometimes be an advantage to removed it altogether.
Old Jul 21, 2005 | 10:46 AM
vroooom ptssssh
It Wasnt Me!
cheers girls
Old Jul 21, 2005 | 05:29 PM
Keith B's Avatar
Keith B
The best rear suspension is off the Mk IV Van - or so Ahmed Bayjoo told me. He said the weak link on the Mk IV was the cheap n cheerful rear suspension he said a multi link set up or the Van beam is the best way to go at the back.
16i front end with the subframe is the best way to go upfront but you'll need the 16i gbox casing to clear the subframe.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
turbowag
Sep 3, 2015 08:07 AM
dal3door
Aug 13, 2015 06:55 AM
