calibra turbo pistons ????
Old Jul 19, 2005 | 11:00 PM
RSTEVE's Avatar
RSTEVE
Default calibra turbo pistons ????
sorry another zvh conversioin question for you all
heard you can use calibra turbo pistons ? any one done this, is this recomended or is there a better option ?
whats involved if i use them ?
can i live with the shame of having vauxhall parts in my ford ?????
Old Jul 20, 2005 | 10:35 AM
andyt's Avatar
andyt
get them mate i have just got a zvh s1 with these pistons engine not run in yet and fook me it pulls
Old Jul 20, 2005 | 07:54 PM
B9DOV's Avatar
B9DOV
Alot of people use them m8 usually for 2.1 zvh, both my m8s have them in there 2.1 zvhs, a wouldnt worry about having vauxhall pistons in your ford as they are not manufactured by vauxhall they are mahle pistons. I would snap them up if you could thou
Old Jul 22, 2005 | 04:21 PM
RSTEVE's Avatar
RSTEVE
im now the owner of a calibra turbo bottom end for £100 covered about 100K but the pistons look in good nick and the car was well looked after when it was running.
Old Jul 22, 2005 | 05:46 PM
ON-UJAH's Avatar
ON-UJAH
Calibra turbo pistons for Zetec Turbo, C20XE pistons (redtop NA) for ZVH.
With the turbo pistons in a ZVH, your compression will be very low - compromising your off boost performance.
I have a set of XE forged Mahles (be careful at some point they used cast pistons instead of the forged ones) - suitable for ZVH. They require machining work to get oil to the pin, and the Zetec rod little end need boring out to press fit with the pins.
JK12
33
Apr 26, 2021 12:09 PM
big_Rad
Sep 15, 2017 09:36 AM
slammedorion
15
Nov 1, 2015 07:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
