Seiko Watches
i got a new one, its an alarm chronograph with a stop watch to 1/5 second, dual time and split time.
problem i got is i chucked the manual by mistake and not got a clue what does what.
i assume that most Seiko watches will use the same buttons to do the same things. anyone know what the topand the bottom buttons do?
not sure i binned the tag that was on it. its in the Argos catalogue but i can't find it on their website. its the titanium one. there is nothing stamped into the back of it which looks like a model number.
if you could find a manual for any Seiko chrograph, i'm sure it'd be a pretty similar set up.
http://www.seiko.co.uk/service_frset.asp
This search can be used to locate instructions for your watch. To do this you need to know the calibre number of your watch. This is a four-character code to the left of the hyphen mark located on the back of your watchcase. Please type your calibre number into the box below and click search.
