Priming that bastard turbo grrrrrrr
Old Jul 18, 2005 | 09:01 PM
rs_daz's Avatar
rs_daz
Default Priming that bastard turbo grrrrrrr
Hi all.
Fitted my new turbo today ..but having a few problems priming it..
Ive fitted a T piece and the oil pressure device for my gauge on the back pf the block
Took the spark plugs out and a coil lead and cranked the car over..after about 10 mins there still was no oil coming out the oil retern pipe to the sump..its new oil and new filter.
And tips?
Old Jul 18, 2005 | 09:43 PM
ON-UJAH's Avatar
ON-UJAH
Take the filter off, and fill it with oil. Pour oil into the filter unions to try to fill the pump.
If oil doesnt come through after about 30 secs there must be a major problem.
Have you taken the head off to see if oil gets up to the valvetrain?
Old Jul 18, 2005 | 09:46 PM
B9DOV's Avatar
B9DOV
Take your oil feed pipe off top off turbo m8 and turn it over to make sure you are getting oil to the turbo first incase there is a blockage at the oil pressure switch or t piece you fitted
Old Jul 18, 2005 | 10:38 PM
rs_daz's Avatar
rs_daz
Yeh il do that tomrw. take that pipe off off and check its not blocked..
Old Jul 18, 2005 | 10:40 PM
rs_daz's Avatar
rs_daz
It has new oil and a new filter il check the oil feed pipes not blocked and just crank it over..
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
