Converting a 4x4 engine to 2wd.....
Old Jul 18, 2005 | 06:27 PM
peteh's Avatar
peteh
Default Converting a 4x4 engine to 2wd.....
what's needed guys? Need a list really to i know what to buy, also do i use a 2wd or 4x4 oil pump and water pump?
Any help would be appreciated
Old Jul 18, 2005 | 06:31 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
realy you could do it with no changes.just the sump,even then you dont have to change that if you dont want to.
Old Jul 18, 2005 | 06:35 PM
peteh's Avatar
peteh
really!!
Old Jul 18, 2005 | 07:08 PM
Mr RS500's Avatar
Mr RS500
Pete
My escoss track car is 2wd ,,
Just changed the sump / oil pump and pickup pipe ,
Remove the shaft ends from the shafts and leave the ends in to hold the front hubs together , Make a brkt for the 2wd gearbox and your done
Easiy , and can be changed back in a day
Old Jul 18, 2005 | 08:17 PM
peteh's Avatar
peteh
I just wana put a cossy engine in a 2wd saph, but the engine i found was a 4x4 one.
Old Jul 18, 2005 | 08:34 PM
peteh's Avatar
peteh
so sump, oil pick-up and oil pump onto the 4x4 engine?
Old Jul 18, 2005 | 08:58 PM
Alvyn's Avatar
Alvyn
when I done it changed sump,oil pump/pick up,bottom crank pulley,engine mounts,had to buy a bailey turbo damper(due to head) also have to rewire the temp sender wire(make it longer as it on the other side)and also changed the turbo oil feed pipe iirc
ps: you can use the 4x4 oil pump and p/up but you have to grind abit of the inside of the sump to clear the pump thou!
Old Jul 18, 2005 | 09:01 PM
peteh's Avatar
peteh
cheers bud, and it worked fine then?
umm nice black 2wd in the sig
Old Jul 18, 2005 | 09:13 PM
Alvyn's Avatar
Alvyn
yes m8 worked fine with no probs at all(had to use a 4x4 water pump hose also)
cheers had it 10 yrs now
Old Jul 20, 2005 | 12:31 PM
2wd's Avatar
2wd
Originally Posted by NORTH YORKS RS SPARES
Pete
Why change the oilpump+pickup....?
Kyle Langford
27
Aug 5, 2019 07:54 PM
big_Rad
Sep 15, 2017 09:36 AM
Oct 9, 2015 07:38 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
