cossie l6, l8 and p8
please help.
whats the difference between the
l6
l8
p8
and are the interchangable. can u swap them with each other.
if not, what needs changing?
l6
l8
p8
If you mean can you just fit a different ECU to the current loom, then yes you can. However, the EPROMs are not interchangeable and the 4x4 cars run a different throttle position sensor that would also require changing if a "non" 4x4 ECU was fitted and vice versa if fitted to a 2wd car.
can any please give me any more details in terms of effect on my engine this ecu will have.
I am running greens and 3 bar at the mo.
Gona be getting a t34 with .63 rear housing, and may change the cams. Still waiting for the review on the intercoolers.
Will it run better with a p8 than a l6. boast kick in. Mapping capability is it better?
Mike. Could there be any problem running a 4x4 Ecu on a 2wd engine. I mean, could that of caused any problems in my car due to the TPS being defferent? (mine is a 2wd engine
with..I think..an L8) Or am I being a t*at as usual
Gareth! how can you put a
after saying that
pmsl.
probably got something to do with why my engine went night night
A P8 is from an RS500 right? so the TPS would be the same as my 2wd one?
after saying that
pmsl. probably got something to do with why my engine went night night
if you mean that you was running a 2wd tsp
cheers mike
, tosser
I'll have a look later
o, by the way. That turbo I bought.....its fucked. Dunno how I didnt notice it there. I checked it well, from one side but didnt do it properly obviously
The play is so bad the blades can hit the compressor housing
1200 quid for a bedroom ornament
, tosser
I'll have a look latero, by the way. That turbo I bought.....its fucked. Dunno how I didnt notice it there. I checked it well, from one side but didnt do it properly obviously
Dom,
Is this up and down play or side to side?
. Up and down is okay, as the shaft sits in a bath of oil when the engine is started, so it needs this freedom of movement, side to side is nicht gut
If it really is fooked, I'm sure Danny will sort you out, he's a good old stick
.If it really is fooked, I'm sure Danny will sort you out, he's a good old stick
If you were still running the 2wd TPS with the level 8 ecu then at WOT you'd have no WOT multiplier working. Not all mapping uses a WOT multipler, but most do, and typically it is in the region of 10 - 20%. If your chip was mapped as such then at WOT you were likely running 10 - 20% lean. (since your 2wd tps was giving the inverse signal of the 4X4 )
You should have noticed the incorrect TPS though as your idle speed contorl valve would have been inoperative, and at cold start would have been very apparent that the car started badly.
Mike Rainbird, erm, im not sure. ill have to check. It is bad though...I will have to check whether its side to side or up and down. He seemed like I top lad.I have PM'd him. But as he needs the money at the mo and he is not a trader then I could see him not wanting anything to do with it.
Karl, Cheers mate. interesting. I was using an A1 rallysport chip, it wasnt live mapped (Mike
I think it could have been an important factor in my engine going kaboooooom
funny because I actually read about this TPS before I blew it up and worried about it for a couple of hours until I forgot about it. lol
) I think it could have been an important factor in my engine going kaboooooom
cheers
maybe i am thick, but wot is closed looped lambda and boost control. Obviously i know what boost and lambda are but what does the closed loop bit mean.
cheers
rich
cheers
rich
Hi, this maybe a dumb question, new to cossies, but is there software available for mapping the L6 ECU (RS500) I doubt anyone here in Aus would have it, we have a dyno and map Autronic, Motec and unichip, would like to knw how to get inside the 500's brain, any advice greatly appreciated
regards Paul B
regards Paul B
Paul,
Yes, Simon at SECS has developed a software package that can live map L6.
Simon Johnson
E-mail Address(es):
simon@s8ecu.co.uk
Simon Johnson
E-mail Address(es):
simon@s8ecu.co.uk
Thanks very much Mike, no answer on his phone (from web site) but I'll keep trying, have you had experience with his systems, or know Simon and how good the system would be ?
regards Paul B
PS the conversion to knock, lambda L8 etc a hard one ? worth it if tuning ourselves ?
regards Paul B
Yes, Simon can be a bit hard to get in touch with sometimes, but the set up works, as a well known (in this country) tuner uses this set up for live mapping L6.
I don't think you can beat a set of det cans, so would always rely on these rather than some for of electronic detection of knock.
The conversion to L8 and lamda is simple enough using the OE parts. Obviously the fuel economy / emissions can be improved, but depends if this is important. You could chat to Stu at MSD about this side of things, as he has stepped up the development of these in the last few weeks.
Mike, thanks very much for your help, I'll try to get in touch with Stu and Simon.
JRST, appologies for partly hijacking your thread, still along the same lines enough I hope, best regs pb
no probs mate. At the end of the day we are kinda talking about the same thing.
Wish someone would just tell me though whats needed to convert to a p8.
sometimes its hard to get a straight answer.
Please help.
Thanx to everyone who replied though
Please help.
Thanks, so I guess we are talking about the same thing - converting to L8 and not knowing exactly how, and some new info for me there - the emulator, could you please explain that, is it in addition to Simon's invention ? thanks. pb
PassionFords Creator
Mike Rainbird,
Funny you should say that.....
https://passionford.com/forum/viewtopic.php?t=58883
elxr8393,
swap top and bottom wires over on TPS plug.
If required add a lambda sensor and Knock sensor.
IF using Pectel software, dont add these as it wont utilise them.
I recomend they are retained.
