Pop went the cossie, and the cossie went pop!!
just got recovered home.
slowing from speed and engine died.no bang or smoke or anything else just died.when you try to start it, it sounds like there is no compression.cambelt is fine, didn't overheat, was running fine!!think the only possibility is the belt has jumped a few teeth.
fingers crossed its not gonna be super expensive!any other ideas what it could be?
sympathy please!!
sympathy please!!
TDC Sensor I think, does it turn over really fast? see if the fuel pump primes when you turn the key? My old 3 door did exactly the same on the first day I got it, not happy, but easy to fix.
Good luck.
Good luck.
Sounds like a cheap fix....
My cosworth went boom at 150mph a month ago and its still off the road, its not a nice feeling so i have some sympathy for you... Altho mine at the minute has stung me around Ł1500 and its still not back together
fingers crossed for a cheap fix.its a run of bad luck for me and a couple mates - one has torn a hole in the floorpan of his bmw and another has blown the gearbox on his focus!gutted for you though ryan.
My front prop came off at 150, smashed off the ground, blew the gearbox and the front diff also went under the stress of it all, clutch also jammed in. So count yourself lucky boyo!!!
Its all the fun of owning an RS though, going on a long trip and not knowing if your gonna come home driving or on the back of a trailer
when this happened on mine it was the bottom pulley,it stripped the teeth off the cambelt causing the top end to stop while the bottom end carried on at 70mph!!!!! that was the last time i EVER drove A2 WWE
I know you have probably checked this but fuel cut off switch or cable leading to it
my spare wheel somehow pulled my wire out on cornering resulting on it dying and not firing up
just a thought mate
just a thought mate
fuel pump runs fine.i think that the cambelt has jumped a few teeth on the exhaust camshaft!which would mean the exhaust valves would be open on the compression stroke - therefore no compression!
he has all ready said it has no compression,how could it possibly be the rotor arm,tdc sensor,or fuel pump cut out?
are you lot just winding him up or are you really that in the dark about how a yb works?
my money is melted piston/pistons.running lean at the end of a high speed run is the norm,especially if the pump is old or standard.
not necassarily much smoke if it has only melted down the side of the pistons,if its put a big hole in then yes,even less lightly to smoke if fitted with a good breather system.hard to say without actually haveing the car in front of us but knowing cosworths it wont be anything simple.
update!!have corrected the timing and there does appear to be plently of compression when turning the engine over by hand and there is no contact between valves and pistons.have tested for a spark at the plugs and that is fine.i think the injectors a clicking(indicating they are working aswell)im starting to run out of ideas now!!
anyone got any??
anyone got any??
may get a compression tester before i do that.anybody know what kinda figures i should be getting from a compression test?would a faulty crank sensor cause the injectors not to fire?
if you got more than 120 psi then its cool i think..
the crank sensor runs the igniton sequence?
the Phase sensor doe the fuel?
(thats how i thought it was anyway)
so you corrected the timing and its still not running?
i deffo have the cams and crank timed up correctly!think i have the dizzy timed up right but am going to double check it tomorrow after checking a picture that was posted up earlier.
the dizzy could be quite easy to get a tooth out
(but it should still sorta run even if it is)
the mark to line it up on kinda hides under the plastic phase sensor cover!
you aint run outta fuel have you mate lol
TBH if the timing was that far out, then its quite possible that there is valve damage
have had another good look tonight and when the cambelt is off there is movement on the exhaust cam pulley.this would indiate that the cam comes away from the hvas.which leads me to believe that the valves are slightly bent.ie not allowing the springs to fully expand and therefore the hvas sit lower.does that sound about right?
Russ Payne
Sep 25, 2015 08:29 PM
