4wd intercooler
Old Jul 16, 2005 | 07:27 PM
pauldowts's Avatar
pauldowts
Default 4wd intercooler
i have a 4wd intercooler to fit to my 2wd, should this a straight swap as i couldnt fit it earlier.
cheers paul
Old Jul 17, 2005 | 10:10 AM
dave cos4x4's Avatar
dave cos4x4
afaik should be a straight swap.
Dave.
Old Jul 17, 2005 | 01:10 PM
Antilagnos8inj2wd's Avatar
Antilagnos8inj2wd
It aint you have to hack the corners off the intercooler
Old Jul 17, 2005 | 08:53 PM
2001ode's Avatar
2001ode
Hi,
Is it necessary to change boost hoses, or is it possible to reuse old hoses intercooler 2wd ?
Regards
Claude
Old Jul 17, 2005 | 09:17 PM
dave cos4x4
the hoses are the same width so no probs there.
Dave.
Old Jul 18, 2005 | 08:16 AM
2001ode's Avatar
2001ode
Thanks, Dave.
Old Jul 18, 2005 | 09:05 AM
Ridgey's Avatar
Ridgey
Since the 4x4 intercooler is about an inch deeper, when i did the swap, i cut an inch or so off the length of my hoses.
I also had to trim part of the radiator (metal part where the intercooler fixes, on the left i think), so the 4x4 would sit down properly. Nothing major though.
good luck.
Old Jul 18, 2005 | 05:44 PM
pauldowts's Avatar
pauldowts
ok thanks, i will try again when i get 5mins
cheers paul
Old Jul 19, 2005 | 12:57 PM
b14dave's Avatar
b14dave
fits easy have to drop rad to get in also need to cut boost hoses down each side bout 1-2inch
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
