Cossie brake problem
Aswell as everything else thats wrong with it, the brakes are playing up too
Got her out the garage earlier, and the little yellow ABS lights were on as normal, but the pedal was rock hard and no brakes
when i drove off a couple of minutes later it was stil the same WTF???
remove the abs relays next to the throttle pedal, make sure there not to hot, put them back in, the disconnect the battery for a few minutes, some times this cures it. we had the same problem with our 3 door.
Red_bull
Aug 9, 2015 08:34 AM
