Vernier Pulleys questions
Old Jul 15, 2005 | 01:46 PM
CraigN's Avatar
CraigN
Default Vernier Pulleys questions
I have replaced the headgasket and cambelt on me car.
My car has vernier pulleys fitted.
before we took head and belt off we marked them all up and made sure they were alighned visually as best we could.
the car runs fine, but im just wondering if it could potentially cause any probs and if i need to get them checked by a pro. ?
any info greatly appreciated
Old Jul 15, 2005 | 01:49 PM
wimwerf's Avatar
wimwerf
if youre not sure about what you did...its always good to let a pro look to your cossie....
Old Jul 15, 2005 | 03:07 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the point of vernier pulleys is so that you can time the cams correctly - this does not always mean that they should align with the TDC marks. it depends on your engine spec and cam spec, but it may be better to advance or retard the cam timing compared to std, although best for std may not be where the timing mark indicates.
Old Jul 15, 2005 | 03:09 PM
D19 STE's Avatar
D19 STE
I would get them checked by a pro and set right if needs be rather than using marks
Old Jul 15, 2005 | 03:14 PM
CraigN's Avatar
CraigN
i didnt explain what i did correctly.
my verniers have allready been setup
i set the car to tdc and then made my own marks on the cams
when i put it all back together i lined up my own marks not the tdc marks on the pulleys
Old Jul 15, 2005 | 04:32 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Should be ok then craig, but if in doubt, get it checked out
Old Jul 15, 2005 | 04:35 PM
CraigN's Avatar
CraigN
it fooking flys now goes really well
holds 2bar of boost on my t34
i dont use that much tho dont think the turbo will last it
Old Jul 15, 2005 | 04:38 PM
If you have dialled them in slightly wrong (ie slightly different to how they were) then you will need it remapping ideally, but i suspect in reality they wont be out by enough to need that.
Is it a thicker head gasket?
If so that will need a remap too!
Best bet might be to pop up to karls just for a very quick livemap to check all is still as it should be?
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
