cossy CO level ? ? ?
what would you expect the CO / hydro carbon level to be on a well set up stage 3 2wd saff, running the the usual greens/t34/chip/3bar /22psi etc????
mines at about 4% but its still running lean at the top end you see, although the plugs are getting black so thats poss to much fuel down low? so was wondering what every one elses was set at!
4% at tickover ?sounds fine. the co screw only controls the co at tickover, once the engine is revved then the chip takes over, if your engine is running lean at top end then its a chip problem , you need to talk to stu (motorsport developments) , some dyno "experts" who say a chip is running lean at top end dont have a clue as to how the management is set up, other times it could be that your running more boost than the chip is set for (but 22psi isnt a lot for stage3 and greens) cheers nomad
Originally Posted by nomad
4% at tickover ?sounds fine. the co screw only controls the co at tickover, once the engine is revved then the chip takes over, if your engine is running lean at top end then its a chip problem , you need to talk to Stu (motorsport developments) , some dyno "experts" who say a chip is running lean at top end dont have a clue as to how the management is set up, other times it could be that your running more boost than the chip is set for (but 22psi isnt a lot for stage3 and greens) cheers nomad
also have a Cossie running greys at 3% on tick over, many moons ago people DID have to run alot more on tick over and say it was because of running bigger injectors etc but NOW technology has come alone way so NOT needed to(maybe your chip etc is one of them)!
the CO screw on the ecu I do believe changes the fueling all the way through the rev range and NOT just on tick over!
mine runs fine at 14.5:1 afr, about 0.5%, abit lumpy. runs alot smoother at 2%.
thats with 500bhp engine on 8 greens.
if spent abit of time wen mappin can get the co right down. and run smooth
the mixture screw is only for idle, as wont even notice the diff at top end, thats all done to map, and fuel pressure its been mapped at.
alvyn nope , the co screw is for tickover only, whats technology got to do with anything ? some people on here boast 1% with greys , mate had it done but no 1% was ever seen. cheers nomad
Matt,
In actual fact it is a software switchable option if its a global multiplier or not.
MOST chips only have the CO enabled for IDLE and LIGHT load adjustments only.
It is hard to say who's chip has what kind of setting.
Generally aim for 2-3% CO as this results in a decent idle.
nomad, which advice is btter?
1) yeah, adjust the screw all you want mate, only does idle...
2) no, CO screw adjusts the multiplier! dont touch
now, given tht there are 2 possibilities as to wht could happen if you touch the screw, which advice do you think is sensible to give to people on a public BB? (remembering most people believe EVERYTHING they read on the internet
jim i took my car down for its mot, it failed on co, i turned the screw gently to bring the co down, went through the mot, turned the screw back up to 4% and everything was hunky dory for ever after, the ONLY way to get my car through the mot was either do this or take off the greens,chip,3bar. now i have always been told by real people that the co screw ONLY affects tickover, i do tend to believe these real people , they are not out to sell you something you dont need. cheers nomad
Originally Posted by Matt
ask him about wanky bling paint instead, he knows about that
matt right ho
richard you can always turn it back up again ? whats the big deal with moving you co screw ? if you remember where it was in the first instance then it dont mean a shit what you did with it in the meantime, so long as you return it after the mot !!. if ford didnt intend that screw to be moved then they would not have made a nice screwdriver friendly hole . believe me. if people want to make a chip that disregards the ford way of of life then they should print it onto the chip face. cheers nomad
im not disputing the fact that you can turn it down for the mot and return it after, im disputing your pisstakes out of me for your inability to believe me telling you something you didnt know. believe me.
got any more leads for sale nomad?
i sold your shit on ebay, the only place they belong
My guess would be that by adjusting the CO level it would change the fueling through out the rev range, when i first bought the car i took it to be tuned by someone in the spot light so to speak who i thought would know what they were doing! They found my CO level to be up at around the 8% mark, so they adjusted it down to be at around 3% but never tested to check how that adjustment had effected the fueling through out the rev range! An the very next day the eng melted a plug causeing all kinds of damage! Now i have a new eng, but i would like to fully understand if poss how it should be set up an what level to if poss!
PassionFords Creator
Ok,
on 95% of Marrelli installations the idle trim adjusts the fuelling everywhere from idle to hard boost. Do not mess with this screw without the equiptment to check what you are doing. As Martin says though, if your putting it back where it was you will obviously be ok.
However...
Why any YB motor would need in excess of 3% is beyond me totally, and round here they will likely impound your car for you if you fail the roadside check, so beware.
Just to be pedantic here... the hole was tamperproofed from new
Call your mapper / chip tuner, and ask them what CO level to set it to and under what conditions. If their advice is illegal and your not happy, all you can do them is change software. Hope This helps.
However...
nomad,
rossco22,
