good or bad?
Old Nov 16, 2003 | 03:02 PM
Default good or bad?
just wanted to check whether i got a good deal or not as u guys obviously no wot u talkin about. i picked up a G-plate 2wd sapphire cosworth thursday nite. full scorpion stainless exhaust system, -31 actuator, full samco silicone hose kit, bailey single piston dump valve, RS500 intercooler, polished ally battery cover, polished coil and air filter heat sheild, K&N induction kit, leather recaro interior, a-pillar mounted oil pressure and boost pressure gauges, original ford radio and equalizer and its been lowered. the only things wrong with it is 1 stone chip on the lower half of the drivers door has just developed into 2 small bubbles and the headgasket is leaking about a pint of water out of the engine just behind the turbo for about every 300 miles. i paid £3000 for it. does that sound about right?
dave
Old Nov 16, 2003 | 03:38 PM
JamesH's Avatar
JamesH
£3k for all that sounds a bargain to me!
Just get all the bad bits sorted ASAP
Old Nov 17, 2003 | 08:33 PM
cool. just wanted to check i dint get ripped off. it gotta cat 1 alarm with auto closure on it as well as 4-pot front calipers and vented discs. i forgot bout them.
dave
Old Nov 18, 2003 | 10:49 AM
Smit's Avatar
Smit
The 60ft Launch King
sounds a good Price Dave
Old Nov 18, 2003 | 12:33 PM
JamesH's Avatar
JamesH
Indeed it does
Old Nov 19, 2003 | 09:20 AM
foreigneRS's Avatar
foreigneRS
Testing the future
standard stuff for 2wd mate unless you got bigger ap's or summat but unlikely for that price.
whether it's a bargain or not depends largely on why the headgasket is leaking. if it's the usual story of being old and blown out, then you got a bargain. if it's cos the head is damaged or the block cracked then probably not, unless you can do all the work yourself and can get things like parts and machining at cost or trade prices.
i wouldn't drive it hard until you've got it sorted cos if it is only the gasket and you rag it, you could make things a whole lot worse.
anyway, hope you get it repaired and enjoy it. give it a good caning down the acle straight.
markk
Dec 2, 2021 06:59 PM
3dr cossie
21
Nov 20, 2015 05:00 PM
Mark RS
14
Aug 11, 2015 11:45 AM
mattman1234
24
Aug 1, 2015 11:46 AM
ginger1979
Jul 31, 2015 09:56 PM
