What would cause a hole to blow through gearbox?
Old Jul 12, 2005 | 02:57 PM
wildheart's Avatar
wildheart
Default What would cause a hole to blow through gearbox?
As above
Got to Derby saturday night after taking fiesta on track at combe and i was cruising about 30/35mph and suddenly bang,a hole blew through box near speedo cable
Thats 2 dead RS's within a week
Old Jul 12, 2005 | 03:04 PM
andyhardy's Avatar
andyhardy
Oil running hot inside causing one of the cogs or bearings to weaken - clutching at straws there though as I don't know too much about gearboxes! (apart from what they do!).
Old Jul 12, 2005 | 03:07 PM
wildheart's Avatar
wildheart
i have noticed the box had been getting a little notchy of late
You can still drive it now ok in a way
Theres no noises/rumbling and it changes fine!
Old Jul 12, 2005 | 03:43 PM
NUTS RuS's Avatar
NUTS RuS
Is the breather blocked causing a pressure build-up on the inside ?? Happened to me at Llandow last year but it blew out the small core plug inside the bellhousing.
Old Jul 14, 2005 | 04:28 PM
wildheart's Avatar
wildheart
Upon investigation it appears the diff has blown
Old Jul 14, 2005 | 05:26 PM
gearboxman's Avatar
gearboxman
Planet gear or planet pin from the diff
Old Jul 14, 2005 | 05:32 PM
Westy's Avatar
Westy
bernster..
if ya read this.. cheers for the advice re: clutch last night Hope the motor sounded well onto the A5
Old Jul 14, 2005 | 05:36 PM
gearboxman's Avatar
gearboxman
Sounded the bollocks actually
.....you stalking me......?
Old Jul 14, 2005 | 05:38 PM
Westy's Avatar
Westy
cheers chap
stalking lol.. i was at the petty station first
assume you'd just been to the wagon for a swift one
mjonathan24
Oct 29, 2015 10:39 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
