Leaking oil..!?
Ay!
My engine has started leaking oil a new place among thousands of other places
so i guess i need to replace the part that is leaking!?
I took a pic to make it easier for yall to help me..
What is the name of this part?? and what does it do??
It only leaks oil when engine is running.
Thanx in advance
Thanx in advance
the arrowed part is the oil pressure switch(its what makes your oil light go out) it could either be leaking through the switch or the thread of the switch if its not tight enough! you could take it and put PTFE tape around the thread to see if that works before getting a new switch.
ok.. thanks
but i think im buying a new one... might as well do it perfect..
i hope its not a expensive part
a little question: will the oil start coming out when i remove the switch??
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
