Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
A challenge...
Old Jul 12, 2005 | 02:27 PM
stuart_md's Avatar
stuart_md
Default A challenge...
Got a strange one here...
1992 Granada, 2l DOHC. It's just developed an electrical fault, randomly it seems like its starved of electric power (for lack of better words!), and nearly cuts out, sometimes cutting out completely. It will always start again right away. Am pretty sure it's an electrical fault anyway, i.e. moving the sunroof when the car's idling will make it splutter and die, even moving the windows up and down will make it struggle a bit. Ive tried the obvious, new battery and terminals etc but I dont know too much about the electrics in these things. Driving me mad, coz it runs perfectly most of the time.
Anyone got any ideas? Much appreciated.
Thanks,
Stuart
Old Jul 16, 2005 | 08:14 PM
Paul_RS's Avatar
Paul_RS
Check the earths, they can make weird and wonderful things happed if they are corroded or broken.
Old Jul 17, 2005 | 06:25 PM
RSeb's Avatar
RSeb
definately an earth problem, sunroof and windows will draw a fair bit of current, characteristic symptoms
Old Jul 25, 2005 | 08:27 AM
boost mad's Avatar
boost mad
had a similar problem on mine twin cam, it ended up being both the starter draining power ( when not in use ) and the earth strap that goes from battery to bell housing which i would replace anyway as it doesnt cost much
hth
MarcusB
Dec 9, 2011 04:00 PM
Northwester
38
Feb 7, 2007 03:24 AM
Stu @ M Developments
61
Dec 1, 2004 11:05 PM
