Blitz turbo timer
Bout £40 I think.
Make sure they link it to your h/brake as described in the fitting. Not only is it required to be in the circuit for it to function, it is also a safety feature in 2 ways. Firstly if anything goes wrong with the car whilst you're driving (as in twith the h/brake OFF), you know that the timer isn't going to cut-in, count down & switch off the engine. Also, if some pikey tries to steal it with the keys out, timer running, as soon as the h/brake is let off, it kills the engine so they won't be able to drive away.
JK12
33
Apr 26, 2021 12:09 PM
