What blocks suit a cossie head for Normally Aspirated
Old Jul 11, 2005 | 06:19 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default What blocks suit a cossie head for Normally Aspirated
Obviously, 200 and 205, are there any others that are suitable off a run off the mill sierra ?
If so, would there be a benefit in running a cossie head, I think you can get close to 200bhp without a turbo ?
Old Jul 11, 2005 | 06:33 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
any pinto block will be fine,you will need to use proper forged intruder pistons and have a lot of head work done,
Old Jul 11, 2005 | 06:39 PM
frog's Avatar
frog
Thanks pete, excuse my ignorance, but which sierra models had a pinto block, or if easier, which didn't
Obviously, XR4x4 and XR4i didn't
Old Jul 11, 2005 | 07:01 PM
Dirty Harry
Super Moderator
there all classed as pintos or OHC mate even the 1600
Old Jul 11, 2005 | 07:02 PM
Dirty Harry
Super Moderator
from teh very first pinto powdered cortinas to the transit van there all the same
Old Jul 11, 2005 | 07:13 PM
Paddy's Avatar
Paddy
Legend
So could you put a cossie head on the engine from a 2.0 dohc sierra? e.g. the GLSi? Was that pinto bottom end too?
cheers
Old Jul 11, 2005 | 07:25 PM
frog's Avatar
frog
Or a GT
Old Jul 11, 2005 | 07:26 PM
Rob's Avatar
Rob
All GT Sierra's are DOHC tho.
Old Jul 11, 2005 | 08:30 PM
carl_harker's Avatar
carl_harker
glsi 2.0 dohc is the i4 engine very different. 1800 sierra is a crapo cvh. Get a new transit 202 block or just a a good 205 block from alater sierra or tranny. You will need to change pistons and skim head to raise compression. Will need to open up the ports a lot. Will need new cams and manual followers. Then fueling to look at twin 45`s min.
Old Jul 11, 2005 | 08:35 PM
Jim Galbally's Avatar
Jim Galbally
and some XR4is are DOHC too
more engines in sierras than JUST pintos :P
Old Jul 11, 2005 | 09:07 PM
frog's Avatar
frog
Thanks for all the answers guys
jessie_rs
62
Aug 6, 2019 09:27 PM
dombanks
Sep 21, 2015 08:38 PM
CrOwSoN15
Sep 10, 2015 07:33 PM
hopper350
Sep 4, 2015 12:53 AM
