mondeo v6 water problems
Old Jul 11, 2005 | 01:18 PM
mart mondeo's Avatar
mart mondeo
Default mondeo v6 water problems
i own a 1996 v6 mondeo....from last week i have had whurrin noise from the area near the water pump, i have removed the water pump and its fine....checked the thermostat and thats ok....also the water levels are up and down everyday. this noise kicks in every 10 secs and goes off again...any ideas anybody?
thanks
Old Jul 12, 2005 | 04:11 AM
pugo's Avatar
pugo
are you sure its not just moosing????????
Old Jul 12, 2005 | 09:51 PM
ajjames's Avatar
ajjames
did you check to make shore that the impellor hasent broken away from its shaft as sometimes they can feel tight but when they warm up it can start to slip
Old Jul 14, 2005 | 07:13 PM
CosKev3's Avatar
CosKev3
As said above m8 check the pump again
If its got plastic impellors they are a wank pump for the shaft spinning inside the impellors
Get one from a motor factors with metal impellor
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
