Well now, the Pro Alloy intercooler is on, but...
Old Jul 9, 2005 | 12:26 PM
James Raby's Avatar
James Raby
Default Well now, the Pro Alloy intercooler is on, but...
I have lost 0.1 bar of boost peak, so peaks 1.6 bar
But seems to hold the boost a bit better, 1.5/1.4 bar, before it dropped to 1.3bar
Has anyone else experienced this?
All I have heard is people have to turn DOWN the boost as it was too high
Just asking incase I have missed anything...
Old Jul 9, 2005 | 01:05 PM
James Raby's Avatar
James Raby
Anyone, please
Just tell me what happened when you fitted yours
Old Jul 9, 2005 | 01:31 PM
james_birch's Avatar
james_birch
check ya hoses! i know its not same...when i fitted my radteck one i lost 4lb of boost!
got car set up turned boost back up to the 17psi...then bang turbo shate a blade out cus its over sped!
Old Jul 9, 2005 | 02:27 PM
James Raby's Avatar
James Raby
I checked all hoses - hunky dory
Old Jul 9, 2005 | 02:28 PM
Westy's Avatar
Westy
i gained boost.. from GRS to Pro Alloy
Old Jul 9, 2005 | 02:29 PM
James Raby's Avatar
James Raby
I didn't - boooo hoooo!
Old Jul 9, 2005 | 02:33 PM
Westy's Avatar
Westy
that cos your gay
what one you go for in the end Raby? fans in between?
Old Jul 9, 2005 | 02:36 PM
James Raby's Avatar
James Raby
nope, cant see how the hell u're supposed to mount the fans
Just fitted older design in the end, easy to fit and remove
If ya can tell me how fans fit, I'll do it tomorrow lol
Old Jul 9, 2005 | 05:19 PM
Šhatter Box's Avatar
Šhatter Box
Old Jul 9, 2005 | 08:42 PM
wimwerf's Avatar
wimwerf
when i was going from my 4wd IC to my pro alloy it flowed a lot better...and no boost drop...
Old Jul 9, 2005 | 08:44 PM
James Raby's Avatar
James Raby
How would you mean by flowing alot better?
I still get damn boost drop though, confused the hell outta me
It's marginly better than my GRS, can't say it's fantastic though, could be down to the settings of the car I suppose
Old Jul 9, 2005 | 11:03 PM
safflad's Avatar
safflad
the older desighn coolers flow faster than new one's but new type such as pro-alloy cool the boost sooo much better if you've lost boost just wind it up a tad
but saying that the pressure you've lost will be made up by the charge being cooler thus denser thus more power for less boost so just eek up the boost an ickle bit to see the gains of you're new fandango intercooler
Old Jul 10, 2005 | 03:42 AM
Project ST's Avatar
Project ST
Sorry if it's a stupid question, but are you measuring boost before or after the cooler?
Old Jul 10, 2005 | 04:53 AM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
James...
There are 8 x fan ties in the kit..
4 per fan,
simply fit the pins through the fan and fasten on the radiator with the rubber washers against the back of the cores followed by the clips.
cut the excess length off the pin after you have fixed them on.
The fans should be fixed centrally on the radiator , side by side , on the front between the radiator and intercooler...
Full instructions are on our web site listed under ' fitting instructions'
As for boost loss...
must be a leak.. first check hoses, followed by checking the core for damage- this I assume is the second hand unit you have purchased?.
Old Jul 10, 2005 | 10:45 AM
James Raby's Avatar
James Raby
Checked hoses, checked core
All is fine
I measure boost after the intercooler
Fudgey
21
Sep 30, 2015 06:19 PM
