fan problem on a 4x4 cozzie 330
Old Jul 4, 2005 | 04:33 PM
330bhpcoz's Avatar
330bhpcoz
Default fan problem on a 4x4 cozzie 330
fans kick in say wen the meter reads say on o but then is dosnt really stop,now at times the fan will go off leaving the fuse wires very hot or if not melted plz help wat can it be im not really making a good description but plz help guys its my 1st 1 lol
Old Jul 4, 2005 | 05:57 PM
The Gravedigger's Avatar
The Gravedigger
I've had plenty of fan problems recently so I'll have a bash at laying down what I know...
As the fans get worn, they use more current, this puts more stress on the wiring, and let's face it the wiring is probably about 15 years old by now anyway right? So... I dunno, best bet maybe replace the fans with new items, and replace the wiring too? I'm not the expert though but someone round here will know
Old Jul 4, 2005 | 07:06 PM
Hectori's Avatar
Hectori
i would check the wiring first. if there is much resistance on wiring, replace it.
then there is two choises after that. buy new fan, or clean and renew old one.
Old Jul 4, 2005 | 08:57 PM
kossykarl's Avatar
kossykarl
hi mate, fan problems are quite common on cossies , the best thing to do is to rewire them straight from the battery through a fuse then a relay , if you look through some old posts you will see that this problem has come up loads of times before - in fact i solved my problem after someone (can`t remember who now ) posted up a wiring diagram - he even makes and supplys the necessary looms but to be honest it`s dead easy - have a scoot through some old posts they make for interesting reading.
cheers karl
Old Jul 5, 2005 | 12:36 PM
Willis's Avatar
Willis
just an idea...
ma mate has a sapph cosworth...
he has redone the wiring for the fans with new relays and fuse holders...
its prob worth doing as he aint had any probs since...
so get rid of the old stuff
Old Jul 7, 2005 | 08:36 AM
330bhpcoz's Avatar
330bhpcoz
cheers guys but for now i will hwve to x wire the fan,also i heard like a spooling sound from the fans probably r worn shame really 1st cozzie so many problems ,having to worry bout the gearbox aswell shit were to start were to get it done no clue
Old Jul 7, 2005 | 10:14 PM
Hectori's Avatar
Hectori
you can make new "bearings" for your fan, if you want to renew old fans. its not that hard job to do, but you must know what you do. the noise is propably the bearings on your fans. i have have that in my 3dr. i will renew my fans, just for the fun of it.
but the fans are quite cheap, so maybe new fans would be smarter. changinf those fans, are easy job.
Old Jul 10, 2005 | 11:31 AM
330bhpcoz's Avatar
330bhpcoz
nice 1 guys
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
FlashRS
Aug 30, 2015 08:07 PM
