actuators
Old Jul 4, 2005 | 01:00 PM
wimble's Avatar
wimble
Default actuators
on my saff the actuator is stamped 14 psi where is this from and whot is the bennifets of this actuator apposed to a -31 or is the -31 a better actuator to have?
Old Jul 4, 2005 | 01:18 PM
CabrioTurbo's Avatar
CabrioTurbo
14psi will just be the pre-set spring rating on the actuator. ie the wastegate will open at 14psi with out pre- loading the actuator
IIRC -31 actuator pre-load is set to about 10psi although you can load em up a fair bit more..
An actuator is an actuator at the end of the day.. all it is is a spring that pushes a bar when the preassure gets too high..
The difference is prob gonna be in how long they last and how good they are actually made..
i would allways buy a 'propper' one ie garret etc instead of a fancy alloy one that prob has a shite spring in it
Old Jul 4, 2005 | 01:45 PM
wimble's Avatar
wimble
the one i have got(14psi) looks like a garret actuator but its silver in sted of gold
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
