Escos - dashboard strange behaviour
I just returned home from a small ride and I had strange situation one moment. I had really hard braking to a corner and after that all th ilumination of the tacho, speedometer and other things - like boost, voltage and oil pressure just dissapeared with an exception of small spot of light in the middle of the speedo. After stoping and switching ights on and of a few times and moving the brightness regulator everything came back to normal. What was that???
Illumination voltage regulater has a bad connecti0on!! I'm pissed but trust me itthe elecftro luminesent box is going bust! the small light is the standard bulb for lightin mileage! not linked to lum inesent control box!
So, how can I prevent this from happening in future? Everything is working great and I am told my clocks look much better then on most Escos, apart from that incident. Schould I worry?
Originally Posted by T38Mat
Mine did the same - diagnosis is correct.
Could you please tell me if I am to look for new clocks or repeir something? I can't really understand sometimes what you mean....
Originally Posted by Damo V
Where exactly id tyhe voltage regulator located?
Had the same problem on my womans old escort, it was indeed the v/reg, ordered new board from ford, as said above about Ł70 but it took ages to come through due to the part being made came from a small company hence the time i had to wait
Originally Posted by Orionzetec
The instrument dimmer switch thingy is finis: 6833787 Price is Ł19.63
Not sure if this will fix the problem though
TurboSystems fixed mine. But its old board out and new board back in and thats it - Good luck! The problem will get worse if u leave it and driving at night with no illumination is not very useful.
Mat
Mat
Originally Posted by Jobbo
Sorry Dude, didn't realise you were in Poland.
I'ts been a hard week!!!
Anyway, you all tell me that I am going to have to change the voltage regulator, am I right? Cleaning or anything like that wont help.
I had the same problem with my large turbo escort, you need to remove your main clocks containing the speedo etc.. Then open it up, you will see a small quite narrow electrical board, this is what is causing your problem, remove this (very carefully) get the numbers off it and Ford should get you one in a day or so for about Ł60 quid, also the small amount of light you are getting is from two regular bulbs put there incase the board fails.
I tried cleaning it up, but this did absolutely nothing, Mine were on and off like a tarts knickers, it's worth the money you pay to have it done Dude. Good Luck.
I think only one bulb works - will change it.
I'm thinking about cleaning it because the problem apeared after a giant flood I had in my Cossie when one of the waterpipes from sunroof came loose - all the water flooded through electric things on the left side of the car (LHD). Maybe something just became dirty. Must check it, and probably buy the thing eventually.
If its the illumination board thing then the finis is: 6748813 for 04/92-10/93 cars and 7003674 for 10/93-01/95 cars
On the Mk 5 & 6 escorts it is VERY common to find water making it's way down the A-pillar onto the tracks in the fuse box, and the soldering looks like it has been done by a trained monkey anyway!. This could cause a whole lot of very funny faults. My friends Escort had the washer jets come on for no reason, stutter at 4k RPM, Sudden stalling of the engine - then it fired up again?!?!? Window switches controling the wrong windows, e.t.c, e.t.c So if the voltage regulator doesn't fix it, that would be my next bet.
Hope you get it sorted
ta
Originally Posted by Paul Eggleton
Ah, this maybe the cause of my rear washer jet coming on when i use the fronts
I have the same, but I suppose it may be a problem with the pump itself. It schould pump only one way at the time and it doesn't.
Piece of piss Dave, You will DEFO be able ot do it I reckon, just bolting no soldering, I was very suprised mate, took me about ten minutes, the 4th time round lol (ford gave me the wrong ones first)
Micro cat listed the wrong ones for my car... mine was near 200 quid, but the ones which were wrong were alot cheaper and will prob be ok for yours
Just be sure to get one with the same 3 letter code next to the big long 94ABblah blah number
the 3 digits will be, abb BBA BAB BCA, something along those lines mate, Dont mind bolting it up for ya if not sure, just make sure battery disconnected
Paul, I reckon your switch assy is at fault, about 60 quid IIRC from Ford, IIRC, there are 2 pumps on the washer bottle, one for front one for rear so dont think it will be that....
155lee
Oct 24, 2015 11:11 AM
