Fao: Gadget, Jano and other cossie manage experts
Need urgent help lads with prob on RST with cossie management.
1. Car will cut out for what appears no reason, just dies on me...usually when slowing or stopping at a junction. Some times it has just died whilst driving along at low speed.
2. Car drives fine then go to accelerate and it missfires...running but no power, done this today, put clutch down and up...when done this car drove fine again...then started to cut out five mins later.
Any ideas?....pulley sensors?
Full car spec at:
http:www.freewebs.com/bideep/
Full car spec at:
Thats the car mate!
Sound like its sensors as thats what most people have thought.
Seems a random fault was fine for first couple hours driving.
What sensors do i need if need replacing?
think top bracket is flimsy which is causing probs
Yes mate your right the TOP SESNSOR BRACKET is a fault.
We offer you a better designed top sensor and bracket at a very good price. This item is laser cut from alloy or stainless steel, our components will never cause you any problems after it has been setup!
www.oddkiddcreations.co.uk
how much we talking for sensor and bracket?
Looked at gap today and adjusted sensor, was fine for while, didn't cut out but accelerating up a hill it did hesitate for a second.
Just like a split second loss of all power.
Seems to mainly cause intermitting fault when car is geting warmer!
Chnaged plugs today and found that old ones were 3 of kp8's and one ngk!
Seems bit better but done 84 miles and it stalled once at junction and sort of lost power till i dipped the clutch and it was fine again.
Also used full tank of fuel in 160miles of fast driving
And i know you didn't say it was one of mine!
i'm up in glasgow, so bit of a trip to get to you
Think who ever got to engine between me and ravi made a rip roaring ass of it
Sensors were plugged in to wrong multi plugs when i first got it!
Rolling roading it on sat, see if anything shows up!!!
Yes, Ravi is my mate, but if you read his feature, i was too busy to help him! The only thing i did for that car was the breatheron the passenger inner wing, it came off my escort when i made a more bling version!
I htink since adjusting the top cam sensor boost pressure has dropped by about 2psi, should this happen
Gary - what breather tank did you get after my one, or who made you one as i wan't a bling one to sit opposite new bailey tank!
Hi mate,
I made another one the same but mad eit from stainless and had a proper tap in the bottom to drain it out
i made it that shape because i had a GRS header tank which was that shape so it was mirror image!
I'd say you need to speak to bailey really for your mirror image one!
mk3ste
Oct 17, 2021 10:09 AM
DavidK
Sep 27, 2015 02:55 PM
