rs 500 help
Old Jun 29, 2005 | 09:45 PM
callum's Avatar
callum
Default rs 500 help
hi i have recently bought a ex touring car spec 3dr was raced in the vecta championships of paul baileys back in the late 80s early 90s car has sum spec although daft bits and bobs missing pic will b up 2moro car hasnt moved in 8yr
strut assembly missing spring helpers ive never seen them or worked with then has anyone any info as its like the spring is to short for strut
where the fuel rail bolts to inlet maifold theres only one bracket i think i got a 4x4 inlet manifold with it have 2wd got two brackets for the rail
thanx
Old Jun 30, 2005 | 04:50 PM
Niall.b's Avatar
Niall.b
get the pics up mate, sounds very interesting,
if springs too short for strut they will drop out of seats when jacked up,
has it 4 or 8 injectors. both rails have 2 brackets, 2wd/rs500 in the middle, 4x4 has one at the front & 1 in the middle
Old Jun 30, 2005 | 08:05 PM
callum's Avatar
callum
am not so sure how to post up pics but giv it a shot in soon as put them on computer the car runs x4 800cc injectors which used to have modified inlet manifold but iam just using standard one to get it up and running my fuel rail has mounting point at either side of itand inlet has only one bracket to bolt to cheers
Old Jul 1, 2005 | 10:55 AM
rsnissan's Avatar
rsnissan
i made a bracket up to fit my 2wd rail on my 4wd plenum. Its simple but works.
I'll try and get some pics of it later.
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Cos500
Sep 26, 2015 01:11 PM
cos elle
Sep 25, 2015 09:52 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
