LSD or not?
Just jack up 1 wheel and see if you can spin it easy. It should turn but it should give quite a bit of resistance.
If you can spin it with a fart then you have the diff out of a 1.8GLS or something like that
The cossies also have larger output flanges on the diff as the drive shaft C/Vs are larger.
Mr C
Not sure if every sierra diff is the same except the cossie but here are a couple of pics.
1st one show's a 2wd cossie flange at aprox 4 1/2" across
2nd one shows a granada cossie flange at aprox 4" across.
I beleive that the granada diff has standard size flanges on it but dont quote me on that.
Thats about all i can give you M8 hope it helps.
the 2wd cossie uses a 108 flange
everything else uses a 100mm flange
so it's either a fcuked diff or someone has swapped the whole caboodle over if it's not got an lsd in it
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 24, 2015 11:11 AM
