removing door cars, N reg escort?
Old Jun 24, 2005 | 11:41 AM
glenbat's Avatar
glenbat
Default removing door cars, N reg escort?
silly question i know, got everything off except the window winder (its an escort van) does the actual arm just pull straight off, held on with a screw or do you wind it anti-clockwise?
cheers
glen
Old Jun 24, 2005 | 02:54 PM
ian sibbert's Avatar
ian sibbert
Glen,
From memory there is a spring clip at the back of the winder where it attaches to the shaft coming from the mechanism, you need a piece of thin wire bent into a hook shape and fish it down the back of the winder until it hooks the clip then pull the clip out, this will alow you to pull the winder handle itself off...
HTH
Ian
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
no1trancefan
Aug 4, 2015 12:48 PM
Old ford
Jul 31, 2015 06:50 AM
