anothe urgent !!!! ref: boost controler wiring
Got the Apexi AVCR boost controler all in situe on the car but now have a bunch of wires that need connecting
any one know what goes where on a Fiesta RST , EFI type ecu????
everythings in japanese , and the little bits thet u can understand is vehicle spesific so of no use what so ever .
and can some one bounce this to the top a bit later as im gonna be away fro my desk all day .
please help fellas , TOTB Qualifying on tuesday so need to get this sorted over the weekend .
if you can scan me the instructions and mail them, or post up today before 3pm your time, i can get the instructions translated for you.
or maybe these help?
http://www.apexi-usa.com/pdfWiring/2.pdf
http://www.apexi-usa.com/pdfWiring/8.pdf
Top man Nick , Should be able to sort it from that lot .
i have one less wire than shown on the diagram , must not need a second live on my newer controler .
I have a list at home somewhere with colour of wire and where to connect to for an OFAC ecu. Its very simple really just need the pinout for the ECu which is in the fiesta haynes manual.
Also definatly use the boost scramble mode on the unit which you'll need an extra switch for as it makes the AVC-R much more useable and can be used as a type of launch control
If you have no luck email me on the address below and i'l forward the list when i can.
gchristophi
Aug 31, 2015 10:36 PM
Escortdriver1
Jul 31, 2015 02:36 PM
