flywheel info needed asap
Old Jun 23, 2005 | 09:32 PM
s3rst's Avatar
s3rst
Default flywheel info needed asap
can anyone please list the outer diameter of there ford flywheel (assuming some of u will have engines out right now!!) and count the teeth on the starter moter and ring gear on fly wheel? also the teeth for the tdc senser if applicable. im about to do something insane unless i can find a compatible flywheel ill have to have one made to spec!
jessie_rs
11
Jun 3, 2019 04:57 PM
cos elle
Sep 1, 2015 06:48 PM
druidgetafix
Aug 15, 2015 10:22 AM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
