380 BHP + 4x4 cossie owners....REF transmission??
Old Jun 23, 2005 | 08:37 PM
Damo V's Avatar
Damo V
Default 380 BHP + 4x4 cossie owners....REF transmission??
What gearboxes do you run???
Actually I'll rephrase that how long do you get out of std transmissions cos I aint spunking money on a new box too ?
cheers
Old Jun 23, 2005 | 08:39 PM
Benn 304R's Avatar
Benn 304R
hmmmmmmmmmm, no more lunching from the essex meet then
Old Jun 23, 2005 | 08:44 PM
dave cos4x4's Avatar
dave cos4x4
launching Ben!
Mate of mine has a standard box,new one, in a car 450+.
Has lasted him and he does not drive slow.
Dave.
Old Jun 23, 2005 | 08:45 PM
Damo V's Avatar
Damo V
The only thing I have "lunched" leaving the essex meet is my clutch
Old Jun 23, 2005 | 08:48 PM
Smit's Avatar
Smit
The 60ft Launch King
Dave + Dom................
The 440+ BHP standard trasnmission crew
Old Jun 23, 2005 | 08:50 PM
Benn 304R's Avatar
Benn 304R
I would leave the standard stuff in tbh see how it goes.
Old Jun 23, 2005 | 08:51 PM
dave cos4x4
Could not pay that much for transmission,
Rather has less power,or take the risk.
Dave.
Old Jun 23, 2005 | 09:04 PM
FletchCossie's Avatar
FletchCossie
DPE gearbox with straight cut 2nd and 3rd gears. Lasted around 3 years of track abuse (Maybe more) from Jason the previous owner and I blew the standard input shaft up within 3000miles of driving (I put it in 3rd @ 90mph ) Got a new one rebuilt and the straight cut gears sounds the mutts
Old Jun 23, 2005 | 09:08 PM
FletchCossie
Forgot to say Ive blown 1 2wd rear diff so far from launching it Will upgrade sooner or later to better front and rear diffs
Old Jun 23, 2005 | 09:10 PM
FletchCossie
Dont ask Dave, Ive cracked the cylinder head and broke the turbo Fixed them both now tho and she's back out every Wed's night How comes your not out and about anymore? Got a few quick cars around atm Will be getting her setup shortly due to not running right, so she should be a bit quicker than before hopefully
Old Jun 23, 2005 | 09:11 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
FFD.
8.5" front,plated9" rear.
enough said then????????????????????????????????????????????
Old Jun 23, 2005 | 10:12 PM
NIL 7090's Avatar
NIL 7090
DPE all staight cut with 584BHP (+ uprated input shaft )4th is quiet as its 1:1 ratio 700 miles up to now so still on test but so far very happy.
Old Jun 23, 2005 | 10:17 PM
DaveEscos's Avatar
DaveEscos
ive just bought a quaife box damo
its off to bernie to have it stripped, checked , peened and polished and rebuilt
Old Jun 23, 2005 | 10:32 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Damo,
If it is making this power with the same turbo as Dave uses, then you "should" be okay (providing you are sensible), as the torque doesn't come in with such a bang as with a normal T34. If it is a standard T34, then about three goes of full boost in 3rd gear will see the teeth rattling round in the bottom of the box .
If you did break it, then you can get a standard replacement 'box for just over Ł500 and get it peened and polished, which would last with the same turbo as Dave is using (as your box is quite high mileage, and so may not be in peak condition to accept the torque this conversion would give).
Old Jun 23, 2005 | 11:57 PM
The Youth.'s Avatar
The Youth.
my stage 3 saph lunched 3rd gear, 6 teeth fell off!!
steve
Old Jun 23, 2005 | 11:58 PM
RANJ's Avatar
RANJ
keep std and peen and polish, unless u wanna spend 2500+
Old Jun 24, 2005 | 05:36 AM
space hoppers's Avatar
space hoppers
its fooking noisy though in it nickolas. im nearly done mate should be ready to take to petes next week
Old Jun 24, 2005 | 08:34 AM
NIL 7090's Avatar
NIL 7090
its not that noisy your just GAY
Old Jun 24, 2005 | 10:39 AM
Damo V's Avatar
Damo V
Benn 304R,
Thats what I was planning to do... what I was trying to assertain was how long it would be before I would be taking it out again
Mike, I'm unsure on turbo yet ... MAY more than likely be a T34...
Re my current box, I have already blown the original box up this year... (3rd gear), so its already had a replacement box, though just another bog std one
Old Jun 24, 2005 | 10:48 AM
Mike Rainbird
Caraholic
Well you know the answer then BANG .
Old Jun 24, 2005 | 10:50 AM
Damo V's Avatar
Damo V
Sheeeet
Old Jun 24, 2005 | 10:55 AM
Mike Rainbird
Caraholic
Yep, that's one of the words that usually comes afterwards .
Old Oct 5, 2016 | 09:13 PM
eel-roy-t5r's Avatar
eel-roy-t5r
done 4 boxes in within a year on a t34.63 and 55lbs blacks
sorry to bring a old thread up
Old Oct 5, 2016 | 10:11 PM
throttle jockey's Avatar
throttle jockey
Dpe is still number 1 in strength and noise I have no complaints with this one either
Fix it (Swedish)I have no complaints with it best noise wise compromise quiet
I first had a oppliger and it didn't go quite to plan but I'm told there are Deffo a good box and seen many with no complaints
Old Oct 6, 2016 | 08:20 AM
smiley's Avatar
smiley
How did the oppliger not go to plan?
Old Oct 6, 2016 | 11:08 AM
Caddyshack's Avatar
Caddyshack
My Oppliger close ratio long box is the making of my car. My engine lunched the box in less than 500 miles (it is the torque that is the killer) and now my car is MUCH quicker in real road use as the EFR is kept in the best part of its power band the whole time....or atleast it would be if MK Motorsport Mark Walker would ship my bits out!
Old Oct 6, 2016 | 09:37 PM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
fixit cr semi straight cut in mine with 4.4 diff (+drop gear) running efr 7163 at 36psi. noisy as hell in a kit car with no sound proofing. originally bought an oppliger from bara but it wouldnt fit cos they have an added section in the middle which makes the box too long
Old Oct 7, 2016 | 03:37 PM
Adam-M's Avatar
Adam-M
That's the problem with mk good parts but takes ages
Old Oct 7, 2016 | 08:57 PM
throttle jockey
Basically the oppliger box was jumping out of 3rd gear straight away after mapping (only t4)anyhow took the box out and back to Bara and the jumping out of gear was poss a sycro ring issue then we looked at the gears and they had burred over the edge of the tooth then Bara was concerned at that time that there was maybe a issue with the quality of the kits and said maybe best not use one and offerd me the fix it kit which suited me as it was the fix it I wanted in the first place but weren't available then so ended as I wanted I have no issues with fix it good quality warranty on teeth too for a few years so as I say not quite to plan
Old Oct 7, 2016 | 09:25 PM
throttle jockey
I don't think the oppliger kit has these issue as a rule maybe bad luck on my part and baras just a bad few sets by the sounds of it never heard any bad info before on them
Old Oct 7, 2016 | 09:36 PM
cossynut2's Avatar
cossynut2
10 Year Member
How have you managed to break 4 boxes in a year? If you were using a standard box with over 500 bhp I could understand it but with your set up a standard box should cope well.
Expensive year then?
Old Oct 7, 2016 | 10:40 PM
gjh's Avatar
gjh
Mega abusive launches?
Old Oct 8, 2016 | 09:03 AM
london_chris's Avatar
london_chris
bara big tooth box, noisy as sin but so far not been able to break it at 380/380
Old Oct 8, 2016 | 11:13 AM
Adam-M's Avatar
Adam-M
4x4 boxes are weak and only need a pull in 3rd gear to rip the teeth apart, your maybe mistaking him having a t5 box instead
Old Oct 8, 2016 | 11:21 AM
smiley's Avatar
smiley
Mine was OK at 380 got plenty of abuse by previous owner be for I had it close ratio opligger running in cars over 700 no problems
Old Oct 8, 2016 | 02:16 PM
cossynut2's Avatar
cossynut2
10 Year Member
You are right ,I was forgetting his is a 4x4 Saff not a 2wd but even so to break 4 gearboxes in just one year must be down to some serious abuse with his driving style.As I said bloody expensive as well!!
