t34 fitting to RST help
Just managed to fit my new turbo to my car after a BIG fooking battle
i had to 'modify' the compressor housing, make a spacer plate for inbetween the exhaust manifold and exhaust housing, weld a boss on to the compressor housing for the actuator feed and 'modify' the actuator bracket.
so now the turbo actually fits ok
BUT the fooking compressor housing is HUGE for now ive managed to bodge a connection together to fit the original pipe from the meetering head to the turbo inlet, but is there an easy way i can fit it onto there?
the inlet on the compressor is 3" so there is no way i can streach the original hose over it!
CheeRS
Phil
i had to 'modify' the compressor housing, make a spacer plate for inbetween the exhaust manifold and exhaust housing, weld a boss on to the compressor housing for the actuator feed and 'modify' the actuator bracket.so now the turbo actually fits ok
CheeRS
Phil
Billy_RS
16
Oct 11, 2025 09:41 PM
kosienutter
31
Aug 22, 2015 09:55 AM
