Standard Escort Cos Boost Guage - Accurate?
Old Jun 22, 2005 | 10:28 AM
Dan_L's Avatar
Dan_L
Default Standard Escort Cos Boost Guage - Accurate?
Hi All,
Is the standard Escort Cos boost guage accurate as mine only goes upto the red dot after it says 1.3 bar and I am sure it used to go further round past that but am not 100% sure. It should go further than that shouldnt it for stage 3 (24 psi)?
Dan
Old Jun 22, 2005 | 11:22 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
About as accurate as the speedo and revcounter (in other words, not very ).
Old Jun 22, 2005 | 11:26 AM
DaveEscos's Avatar
DaveEscos
funny that... before it melted.. my esc cos speedo was spot on to the Tom Tom Go that was in it!
Mike1's Avatar
Mike1
Perhaps the spring has weakened and it's not holding boost as well as it used to?
Old Jun 22, 2005 | 11:40 AM
Dan_L's Avatar
Dan_L
I have just had my clutch done on my car so I was checking things out a lot more last night when driving it for the first time since so I am not sure if its dropped since I have had the clutch done or it was like that before.
On another note cheers for the great service Mike. I am impressed with the AP Organic clutch. I thought there was a problem with my gearbox because it had always been pretty hard to get it in second when accelerating hard with my old clutch even when new, but it goes in fine now with the Organic one .
Old Jun 22, 2005 | 02:23 PM
Azrael's Avatar
Azrael
I have standard boost gauge with larger scale by Suhe Motorsport in germany and it's suprasingly accurate. Shows exactly the same as my tuners pro boost manometer he takes out in cars to check boost.
Old Jun 22, 2005 | 02:52 PM
Mike Rainbird
Caraholic
Dave you flid, you have 18" wheels, which gear it up by 10mph, so fitting bigger wheels MAKES it accurate (I thought you were clever ). If you had the standard ones on, you would have found a big disparity .
Dan,
No problem .
Old Jun 22, 2005 | 02:54 PM
Azrael's Avatar
Azrael
Wel talking about speedo - mine shows TOO SMALL speeds at 200+ kph. At 6500 rpm it shows only about 240kph.
Old Jun 22, 2005 | 03:11 PM
Billabong's Avatar
Billabong
Dan,
No problem .
My speedo was only a couple of mph out vs PF's timing gear
Old Jun 22, 2005 | 04:15 PM
Mike Rainbird
Caraholic
Bill,
Ducks don't count .
Old Jun 22, 2005 | 04:45 PM
Billabong's Avatar
Billabong
Vincereese
Jun 1, 2023 09:14 AM
Carlbacciochi
24
Jun 30, 2016 04:31 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
