pick up on the st170 - is it poor or is it mine?
Old Jun 21, 2005 | 09:09 PM
iangoddard's Avatar
iangoddard
Default pick up on the st170 - is it poor or is it mine?
recently bought the 170 and have been impressed with the performance as a person who did not rate fords previously - i have seen the light!!!. bought a 53 plate and the pick up in first gear seems to be poor in comparison with the rest of the gears. is this right? if so can it be improved? i have been left standing at lights by far less powered cars - but have caught them up.
Old Jun 22, 2005 | 09:35 PM
MURV69's Avatar
MURV69
hi m8 I got a 53 plate st too and also find 1st a tad sluggish, mine comes to life in 3rd & 4th
Simon
Old Jun 24, 2005 | 06:34 PM
clayton Borg's Avatar
clayton Borg
Default Re: pick up on the st170 - is it poor or is it mine?
iangoddard,
If it makes you feel any better then try driving a Focus RS!
Mine feels slugish in first and i have been beaten at lights by lower powered cars, but im keeping it standard to retain the value and im not that bothered as i leave them standing in second upwards
Old Jun 24, 2005 | 06:40 PM
iangoddard's Avatar
iangoddard
for the extra 8k to buy the rs and the heaven knows how much more to insure it i think the st170 will be fine.
Old Jun 28, 2005 | 08:17 PM
st3v3's Avatar
st3v3
my 1st gear is fine and 2nd and 3rd and all the others,i can pull a fair speed out of mine fairly quick,not sure about 1st but in 2nd i pull about 70ish mph.
try turning off the traction control and then buy your self an aftermarket air filter for starters,i put a K+N panel filter in mine (cheapskate i know) but i noticed a good diference,also the get the air deflector that points all the air straight in to the intake snorkle that will help also.
K+N panel filter Ł30 ish
air deflector Ł8.00ish from ford
you should notice a difference then.
Old Oct 18, 2005 | 10:48 PM
lewismattholie's Avatar
lewismattholie
Default st170 performance
hello mate when you pull away hard is the air con on if so try with it off i noticed the difference in fact my air con is always off only put it on when it is that hot could be something u already know.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
