boost for 500+bhp
Old Jun 21, 2005 | 06:22 PM
cosworthbg's Avatar
cosworthbg
Default boost for 500+bhp
What boost is needed for an YB to get 500+bhp?
Old Jun 21, 2005 | 06:24 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
more than 7psi
ballin's Avatar
ballin
depends on a lot i should imagine, what turbo for a start?
Old Jun 21, 2005 | 06:30 PM
cosworthbg's Avatar
cosworthbg
GT30/40R
Old Jun 21, 2005 | 09:35 PM
Default Re: boost for 500+bhp
Mine made 511bhp @ 1.2 bar (17psi) on the Dyno.
Old Jun 22, 2005 | 07:21 AM
cosworthbg's Avatar
cosworthbg
On what turbo that pal?
Old Jun 22, 2005 | 07:31 AM
GARETH T's Avatar
GARETH T
why the face? he answered your question, and too be fair too rod he isnt one too bullshit
Old Jun 22, 2005 | 07:51 AM
Turbo - head - cams are all relevant to power LOL...
Mine is @ 2.1 bar and won't make 500bhp LOL
Old Jun 22, 2005 | 08:01 AM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
Proper engine, making proper power from the engine, not the boost.....
Big Love Rodders.....
Old Jun 22, 2005 | 08:35 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
GT30 with 0.86 a/r exhaust will make 500bhp with the correct head / cams etc at around 22-25psi (depending how well matched the components are and how close to det you are prepared to go).
Old Jun 22, 2005 | 08:44 AM
Best way to build a turbo engine IMHO is to treat it like an N/A motor in terms of trying to increase the volumetric efficency as much as possible through things like headwork and getting the cams right (although unlikle N/A you want to avoid too much lift on overlap of course) then that way you dont need a massive amount of boost to make good power, the other way of course is to rev the tits out of it so that you are making more bhp for the same amount of torque.
I suspect rod does a bit of both of those things, but i doubt you will get much details out of the wiley old sod
Then on the turbo side of things bigger is better in terms of getting power from as little boost as possible buy obviously has a downside in spool up time, and same goes for intercooler, the cooler the charge the denser it is so the high the number of moles entering the chamber for a given volume of flow at a given pressure.
So to answer your question, somehwere between about 15 and 50 psi depending on engine spec!!!!
Old Jun 22, 2005 | 09:24 AM
gt35 made 614bhp @ 2.2bar on pump, now on gt40 @ 2.5 bar .
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
