S2 ERST - Escos brakes
Old Jun 21, 2005 | 10:11 AM
Jonzy's Avatar
Jonzy
Default S2 ERST - Escos brakes
What discs are required for it to be a direct bolt on job, 2wd discs? If spacers are needed, how big do they need to be and where do they sit? i.e between the disc and hub face or between the caliper carrier and the hub.
Old Jun 21, 2005 | 11:20 AM
S1MAN's Avatar
S1MAN
3 door disc's and Escort/Sierra 4*4 calipers with 1 mm thick spacers(washers) between the mating face where the caliper carrier bolts to the hub casting.
Colin.
Old Jun 21, 2005 | 03:28 PM
Jonzy's Avatar
Jonzy
Thanks
Old Jun 21, 2005 | 03:52 PM
david's Avatar
david
Colin.
Exactly as above mate, can use 2wd saff discs and also granada cossie callipers are the same as esc cos /4x4 saff.
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
