whats that plug on the amal valve for ?
Old Jun 18, 2005 | 05:38 PM
Combi_Chris's Avatar
Combi_Chris
Default whats that plug on the amal valve for ?
as above really, founf a plug missing so i plugged it back on, made no difference that i can tell of, also the lowest pipe on the amal is gone , is that ok ?
Old Jun 19, 2005 | 10:20 AM
Combi_Chris
bttt
Old Jun 19, 2005 | 10:26 PM
GrimmeRS2K's Avatar
GrimmeRS2K
the wire is for the power to amal valve, if u notice no difference when unplugged your amal valve doesnt work, i ran mine with the pipe at the bottom disconnected, with the one in metering unit blocked up
Old Jun 20, 2005 | 10:54 AM
Combi_Chris
the bottom pipe on mine seems to be gone also , what does the amal valve do exactly ?
Old Jun 20, 2005 | 12:01 PM
db's Avatar
db
The amal valve is a way to help boost rise quickly at the beginning of boost build up.
At lower boost levels the amal valve is powered by the ECU and the boost from the compressor diverted to the airbox, hence allowing the boost to build quickly. At a certain level the power is taken away and all boost will be going to the actuator.
Without amal valve boost would be going to the actuator from the start, the actuator spring will give way and start opening the waste gate a bit from the beginning of boost. In this manner it will take longer to build boost.
This of course applies to a standard set up. A -31 actuator with a much stronger spring than standard, will give way to the boost pressure later.
Old Jun 20, 2005 | 12:22 PM
Combi_Chris
so as far as ticking over goes this will have zero effect ? as i have an unstable tickover
Old Jun 20, 2005 | 05:29 PM
ON-UJAH's Avatar
ON-UJAH
A leak in the pipe from amal valve to the metering unit will give you runing problems - the RST is a closed system, any leak causes chaos.
Old Jun 21, 2005 | 09:41 AM
JamesA_RST's Avatar
JamesA_RST
so whats the idea of removing the pipe which goes from the Amal valve to the metering head?
Old Jun 21, 2005 | 10:02 AM
GrimmeRS2K's Avatar
GrimmeRS2K
if u block the metering unit pipe from the metering unit, it will run better IMO,mine did, instead of just dumping the air back into the metering unit, with the pipe removed from the amal valve it will go into the air, just like running a 3 way bleed valve,
mine boosted up a bit quicker, and felt more solid, as long as u block the metering unit one off!
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
