What plugs for a Stage 3 Saff?
Old Jun 14, 2005 | 09:15 AM
mint_s2's Avatar
mint_s2
Default What plugs for a Stage 3 Saff?
I am currently running NGK R7234-9's but apparently these are no longer available. Can I use the replacement for these - the NGK R7436-9 or can anyone recommend any other plugs?
Old Jun 14, 2005 | 11:03 AM
rabmc's Avatar
rabmc
Think C-57`s ar fine but wait till someone confirms , my friend is running them and has T4 , 8 inj set up , 22-30 psi and changes them regular and has recommended them to me so this is what im probably going to run i my saff which is stage 3 also hope someone confirms though
Old Jun 14, 2005 | 10:56 PM
snow*'s Avatar
snow*
You could try the Motorcraft AGPR-12PP8 plugs if your fueling is spot on.
Or if you fueling is slightly out as mentioned in the post above me the Champion C57C is probably not a bad choice
[EDIT] I notice the Champion C57C Spark Plug is no longer being manufactured, Do any of you guys know if a Stage 3 Sapphire should now use the old Champion C57 or the new C57CX?
Old Jun 15, 2005 | 10:00 PM
mint_s2's Avatar
mint_s2
Thanks for your comments. Does anyone run Ford 071's?
Old Jun 16, 2005 | 12:13 AM
Smit's Avatar
Smit
The 60ft Launch King
Keep with NGK 9's. Best plug IMO but also the most expensive......
C57/59's are ok
PP8's DON'T YOU DARE have seen many horror stories of these melting and melting pistions at GREAT expense, Avoid!
The ford 071's i heard good things about upto 450bhp
Choice is yours really. Depends on how deep ya pocket is!
Old Jun 16, 2005 | 09:24 AM
snow*'s Avatar
snow*
Hey guys , can anyone give me a propper part number for the Ford 071's.
Ford New Zealand does not have them in stock, but can order them from the U.K if I provide them with the full product code
Old Jun 16, 2005 | 02:02 PM
wongthecorrupter's Avatar
wongthecorrupter
ngk 9s if you can get some.
Old Jun 26, 2005 | 08:43 PM
KSA-Cossie's Avatar
KSA-Cossie
1120834
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
A.t.p
Sep 29, 2015 05:04 PM
deathrider666
Sep 28, 2015 06:12 PM
