HELP p100 panels/suspension
Old Jun 13, 2005 | 09:16 PM
cossywal's Avatar
cossywal
Default HELP p100 panels/suspension
i am trying to restore a p100 and am looking for somewhere to get panels for it, also does anyone know where i can get a set of leaf springs or blocks to lower the pick up.
cheers
Old Jun 14, 2005 | 02:48 PM
rich2302's Avatar
rich2302
check here for panels
http://www.bodyshopwarehouse.co.uk/default.asp?go=8
and you will be able to get your leafs heated up and the curve taken out, or you may be able to change the location of the axle i.e. if the leafs run over the axle then you could move them under the axle which would drop it by 2" or so
Old Jun 14, 2005 | 03:36 PM
cossywal's Avatar
cossywal
cheers
Billy_RS
16
Oct 11, 2025 09:41 PM
Ian1964
12
Jan 26, 2021 11:57 AM
cossie04
PassionFord Swap Shop.
Jan 26, 2009 02:03 PM
