Nissan Pulsar GTIR
Old Jun 13, 2005 | 12:40 PM
John Laverick's Avatar
John Laverick
Default Nissan Pulsar GTIR
A mate of mine has just bought one.......any good forums on the net??
Anyone know about tuning them as he wants a front brake upgrade and some more power
Old Jun 13, 2005 | 12:41 PM
Ginge !'s Avatar
Ginge !
just finding my feet
speak to RSNISSAN, hes good with them mate
Old Jun 13, 2005 | 12:43 PM
RichardPON's Avatar
RichardPON
At least he's going for the brakes - the standard ones are appaling!
Old Jun 13, 2005 | 12:46 PM
rsnissan's Avatar
rsnissan
http://bb.gtiroc.com/
datsun Gtir forum
bar of boost, mongoose, filter, front mount will be decent enough around the 280 BHAP mark
Sort the supension out lots options best i found was GAB adjustables on the road.
The most important thing to do first is the brakes
hispec are probably the easiest as a bolt on conversion but not the best.
B19-TRB's Avatar
B19-TRB
chocolate engine!
same as the 1 in my car!
just he got a better inlet manifodl & waste gate!
1 bar of boost, air filter zorst boost controller! might need a uprated fuel pump aswell! intecooler & should b around 300hp!
if he goes ehad gasket & bigger turbo then lookin @ 350hp but wouldnt wannna run much more than thta on the standard internals!
Old Jun 13, 2005 | 12:52 PM
rsnissan's Avatar
rsnissan
Originally Posted by B19-TRB
chocolate engine!
The whole head is different (only slightly though) plus GTiR has Throttle bodies and a slightly different tubby.
Old Jun 13, 2005 | 12:57 PM
B19-TRB's Avatar
B19-TRB
still got the choco bottom end though yea!?
I thought it was just a larger wastegate!? didnt realise it was a different turbo aswell.
Old Jun 13, 2005 | 01:00 PM
John Laverick
Thanks for the replies guys.......I've put a post on the Forum above.
Is there anywhere in the Stoke area who can chip it etc??
Old Jun 13, 2005 | 01:09 PM
rsnissan's Avatar
rsnissan
larger exhaust housing on Gtir so will support a bit more power
Pulsar has top feed low impedance injectors and are larger than the S/RPS13 and S14 ones (S15 has 480cc injectors)
They use the SAME pistons (the compression ratio difference comes from the larger combution chamber)
Pulsar has a little stronger rods
Pulsar has 19mm rod bearings with 360* oiling
Pulsar has different flywheel and clutch
Pulsar has higher capacity water pump
Pulsar has higher capacity oil pump
Pulsar has Larger valves
Pulsar has Larger combustion chamber
Pulsar has better valve pockets
Pulsar has larger flowing intake and exhaust ports
Pulsar hasQuad throttle bodies
Pulsar has solid lifters
Pulsar has larger head bolts
Pulsar has 20% stronger main bolts even though they are the same size/spec.
oh and the blocks are slightly different too
but yes the pistions are still made from choclate (just drop some forged bad boys in and youe laughing)
but you still have the gypo s14 engine
Rstar_man
143
Jul 20, 2020 11:16 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
anthony lea
18
Sep 20, 2015 10:43 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
ekjim
Aug 17, 2015 08:57 PM
