xr2 help
Old Jun 13, 2005 | 10:33 AM
the saint's Avatar
the saint
Default xr2 help
I need some help on a couple of thing on my xr2, i want to track the car and its soon to be tuned around the 135bhp mark but i would like to run bigger brakes(rsturbo) but then i`d need to have 15ins rims to go over the brakes, would the car still handle as good as it does now on 15`s???
what suspension do you use on your fast road/track xr`s???
Old Jun 13, 2005 | 11:09 AM
a15gmr's Avatar
a15gmr
u will be ok running 14's with frst brakes...... if ur worried about handeling mate!
Old Jun 13, 2005 | 11:19 AM
Brookesy's Avatar
Brookesy
i think the spax or koni suspension kits ok for them
Old Jun 13, 2005 | 12:10 PM
the saint's Avatar
the saint
when i bought the car it had gaz shocks all round but the fronts were fucked, the back ones are fine and are still on the car so they can stay
are the frst brakes any good???
Old Jun 13, 2005 | 12:13 PM
a15gmr's Avatar
a15gmr
i've never had a problem with mine
Old Jun 13, 2005 | 12:19 PM
Brookesy's Avatar
Brookesy
Frst brakes are good yes just get some decent pads and discs
Old Jun 13, 2005 | 12:22 PM
the saint's Avatar
the saint
and i take it they fit on with no mods needed
Old Jun 13, 2005 | 12:30 PM
a15gmr's Avatar
a15gmr
i'm not sure on that one mate cause they do come with ABS ! !
Old Jun 13, 2005 | 12:47 PM
Brookesy's Avatar
Brookesy
Should do as the ERST brakes fit or fit the RS2000 brakes instead the abs is only a sensor
Old Jun 13, 2005 | 01:14 PM
the saint's Avatar
the saint
ok guy thanks i`ll look into it
what about the rear brakes could something be done about them do you know???
Old Jun 13, 2005 | 01:29 PM
Brookesy's Avatar
Brookesy
You could carry out a rear disc conversion if you want
Old Jun 13, 2005 | 01:42 PM
the saint's Avatar
the saint
yeah i could but would it be an over kill??? what about just using bigger drums like the rst??? to be honest th car would probably be good enough with just uprated fronts but its something to look into i guess
it looks like i have found some cheap front erst brakes so 15`s it will be
Old Jun 13, 2005 | 02:05 PM
Brookesy's Avatar
Brookesy
just change the flexy hoses for stainless jobbies and make sure their adjusted and you should be fine
TPM961
Jan 15, 2018 10:50 AM
mondeomark
Sep 28, 2015 06:28 AM
Ebonycossie4x4
15
Sep 2, 2015 11:40 PM
Ben26
Aug 27, 2015 08:56 PM
Brian
Aug 17, 2004 11:28 AM
