S2 RST boost problem............
Old Jun 13, 2005 | 09:36 AM
rsdene's Avatar
rsdene
Default S2 RST boost problem............
wondering if anyone can help. on my bro's rst the car will only boost 4psi. then floor it again still 4 psi. come to a round about large it in seconds holds 14psi like it should. came to the next round about and it will only boost 4 psi again tried a new -31 still no good. any ideas???
ta
Old Jun 13, 2005 | 10:42 AM
DanRSturbo's Avatar
DanRSturbo
How's it setup ? Does it have a 2 stage boost control on it ?
Old Jun 13, 2005 | 11:33 AM
rsdene's Avatar
rsdene
it has a chip'd ecu. from a mates car that was running fine. he still had the problem when running standard boost and chip.
Old Jun 13, 2005 | 11:43 AM
DAN P's Avatar
DAN P
boost leak
Old Jun 13, 2005 | 11:55 AM
3drstretch's Avatar
3drstretch
Is the amal valve plumbed/wired in properly
Old Jun 13, 2005 | 12:02 PM
CabrioTurbo's Avatar
CabrioTurbo
if it runs 14Psi sometimes and only 4 other times IMO it is prob something to do with the wring to the amal valve or the amal valve itself that it fooked.
Old Jun 13, 2005 | 12:11 PM
B19-TRB's Avatar
B19-TRB
I'd say amal valve is the 1st place to look!
Old Jun 13, 2005 | 04:59 PM
rsdene's Avatar
rsdene
lovely i'll give it a go! thanks alot for your help
ta dene
Old Jun 13, 2005 | 09:19 PM
JamesH's Avatar
JamesH
HTH Dene!
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
A.t.p
Sep 29, 2015 05:04 PM
